The mission planner indicates that I got to 120km. Seems reasonable, flying speed was about 14 m/sec for two hours and 25 minutes. That is about 120km.
@Hein, you mean the camera? I was thinking the two batteries
@Tiziano - just mount it under the wing? I do that with all my Skywalkers. I add a small counter weight right at the tip of the opposite wing. It keeps the camera away from dirt as well.
Thanks David for sharing your setup. I am actually trying to use the Techpod for aerial mapping and the Sony Alpha does not fit. Maybe I should create some external battery holder
There's code for a baro alt base station to remove for the long term drift. Someone just needs to build the hardware.
On flights like this has anyone experimented with giving the GPS altitude more bias using ALT_MIX: (http://plane.ardupilot.com/wiki/arduplane-parameters/#gps_to_baro_m...)
I know it's claimed that GPS altitude is notoriously inaccurate but is it really that bad for this purpose?
http://diydrones.com/profiles/blogs/lynx-m-3-hour-mapping-endurance
Baro altitude drift can be nasty with long flight times. We've had to max out the GND_ALT_OFFSET over the course of a 3 hour flight. Large temperature changes appear to exacerbate the drift, such as flying early morning to mid day.
Heres a post of our Lynx M with a 186 minute log.
Another design by Wayne Garris (TechPOD creator) which was stolen, see his sly comment near the bottom.
1
2
of 2 Next
