I wanted to try my hand at a true "DIY" project, designing and building my own micro quadcotper frame and writing my own firmware in C++. In this post I will describe the frame and build; in my next post I will talk about the firmware.
Excluding stuff I had lying around the shop, (heat-shrink tubing, EC-3 connectors, velcro, cable ties, etc.) the cost came to just under $170:
- 3D-printed frame "free"!
- Flight Controller: Flip32 (Naze32 clone), with Spektrum RX mount removed to expose 3V. $15
- Receiver: MicroFrX by Curtis Fissel. $16.
- ESC: BLHeli 4 in 1 ESC - 12A, with male EC-3 soldered on. $34
- Motors: RMRC Black Series 1306 3300kv ( 2 CW, 2 CCW) $56
- Props: 3030x3 glass composite $8
- HQPROP 3030X3 - BLACK CW
- HQPROP 3030X3 - ORANGE CW
- HQPROP 3030X3 - BLACK CCW
- HQPROP 3030X3 - ORANGE CCW
- Battery: Turnigy nano-tech 1000mah 2S 25~50C Lipo Pack $8
- Fasteners:
- M3 nylon machine screws (20mm, cut down to around 5mm) (4) $8
- Nylon 6/6 Male-Female Threaded Hex Standoff, 4.5 mm Hex Size, 5 mm LG., M3 Thread (8) $13
- Dese nuts (4) $11
Here's the frame, fresh out of my LulzBot Mini printer:
Before adding any components, I inserted a velcro tie to keep the battery in place:
Here's the amazing RMRC BLHeli 4-in-1 ESC with motors and EC-3 battery connector soldered on:
Here's the BLHeli mounted on the frame. I should've used the thinner (4.5mm) standoffs on top and bottom to avoid damaging the circuit!
Next it was time to make a custom jumper for the tiny 3V FrSky-compatible CPPM receiver, which is not 5V tolerant. I un-soldered the 3V Spektrum header from the Flip32 and jury-rigged a little three-pin jumper connection:
Here's the super-tiny FrSky-compatible receiver from Curtis "Beef" Fissel (of Beef's Brushed Board fame). This photo shows the receiver after I soldered on a three-pin header, solder-bridged the bind pads, connected it to the Flip32, powered the Flip32 through the USB port bound the receiver to my Taranis, and un-soldered the bridge:
You can see the completed project at the top of this post. Although I could have used Baseflight or Cleanflight to configure the board, I used my own C++ firmware, adapted mostly from Baseflight. Having never configured such a tiny vehicle before, I struggled for a while with the PID settings. Eventually I just divided all the default values by two, and that worked fine, giving me the smooth flight shown in the video.
In a follow-up post I'll discuss the C++ firmware that's flying the 'copter.
Flying weight is 150g.
I just tested on a full charge (2S battery), and got the vehicle to hover at around 55% throttle -- which agrees with your 50% figure, rather than the 80% you get from simulation.
Do you have a guess as to where you throttle is at hover? I ask as simulations show that a 2s battery with that motor and prop may hover at ~80% throttle. Even with the added weight, 3s and 4s batteries show throttle at hoover much closer to 50%. Given how small this is, it seems possible that the simulation just doesn't represent it well.
What is your flying weight?
Thanks, Phillip
@Patrick: Great minds think alike (and so do you and I!) ... instead of Gazebo, my students and I used V-REP to code up a Python-based simulator. So my other goal for the week is re-writing the flight controller for the sim, using the Hackflight firmware.
The Eachine hack is schweet! But as soon as I see the Keil toochain, ST-link, MDK and all that, I run screaming from the room ;^) Here's the complicated procedure I prefer:
% make flash
For debugging I get by with printf(). I gladly accept the label of Primitive Savage that goes with this among many engineers.
Yeah .. Better keeping this option for the Gazebo Plugin == Sim -On - Flight :-)
Getting back to the root seems to be the trendy these days, I really enjoy hacking and flying micro drones with this group: http://www.rcgroups.com/forums/showthread.php?t=2512604
And incidentally, Iam waiting for a NAZE32 clone to retrofit my quad 250 project, so timing is good :-)
@benbojangles: Sorry about the thingiverse link. I just checked and it appears to be publicly available now.
@Patrick,Phillip: As you'll see (probably this evening), I don't have a branch/fork/release of Baseflight/Cleanflight. I stripped the Baseflight firmware (around 16K lines of C) down to around 1100 lines to support the minimal kind of old-school firmware I loved from the Arduquad days: IMU + RC + PID controller. Then I wrapped it in a crunchy C++ coating for Arduinoheads like me ;^) It's an education / research tool more than anything.
Since I mostly ripped the code from Baseflight, calling it SimonFlight would be dishonest. So I'm calling it .. Hackflight!
Nice build... now I want one.
I assume this will be coming in a future post, but any hints on what you are changing in your version of Base/CleanFlight?
Cant wait to get the new SimonFlight Stack :-)
oops the frame link ain't working anymore :(
nice frame find. Most people don't realise that the most common 3D printers have a limited print diameter of about 180mm so this fits without having to slice it into pieces.
1
2
of 2 Next
