Hobbyking has launched 4 new camera systems on their website today.
1. 1/3-inch SONY CCD Video Camera
The camera uses a quality glass lensed SONY CCD system.
Included:
1 x SONY CCD 1/3inch Camera
Camera specifications:
CCD sensor type:1/3 color SONY CCD
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
Scanning system: Interlacedscanning
Synchronization: System:Inter
Horizontal resolution:420TV line
Minimum Illumination 0.01LUX/F1.2
DSP+CCD:CXD3142R+405AK
S/N Ratio: 48dB
Gamma Modification: 0.45
Whitebalance: Auto
Auto backlight compensation: Auto
Lens: 3.6MM
Audio:No
Input voltage: 9~12.6V
Electric current 80MA
ElectronicShutter: 1/50 (60) ~ 1/100,000s
Video output: 1.0VP-P compositevideo
Operation Temp.: -20~50
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
S/N Ratio: 48dB
Whitebalance: Auto
Lens: 3.6MM
Audio:No
Flight time: Approx 60min/100mah 3S
2. 900 MHz 200mW Tx/Rx & 1/3-inch CCD Camera
12 Channel 900Mhz Tx/Rx video system with CCD camera. Great for FPV systems in countries with less restrictive RF power output.
Included:
1 x 900Mhz 4 channel Video Transmitter (200mW)
1 x 900Mhz 12 channel Video Receiver
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
S/N Ratio: 48dB
Whitebalance: Auto
Lens: 3.6MM
Audio:No
Flight time:Approx 60min/100mah 3S
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
S/N Ratio: 48dB
Whitebalance: Auto
Lens: 3.6MM
Audio:No
FPV Transmitter specifications
Channel: 4-Ch, AV synchronization
Power: 200mW
Input voltage: 12V
Weight: 18g
Input voltage: 12V
Weight: 18g
Channels: 4 (0.9G 0.910G,0.980G,1.010G,1.040G)
3. 900MHz 100mW Tx/Rx & 1/3-inch CCD Camera
12 Channel 900MHz Tx/Rx video system with CCD camera. Great for FPV systems in countries with ristrictive RF power output. The 100mW
system is legal in most countries.
Included:
1 x 900Mhz 8 channel Video Transmitter (100mW)
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
S/N Ratio: 48dB
Whitebalance: Auto
Lens: 3.6MM
Audio:No
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
S/N Ratio: 48dB
Whitebalance: Auto
Lens: 3.6MM
Audio:No
FPV Transmitter specifications:
Channel: 8-Ch, AV synchronization
Power: 100mW
Input voltage: 12V
Weight: 29.9g
Input voltage: 12V
Weight: 29.9g
Channels: 4 (0.9G 0.910G,0.980G,1.10G,1.040G)
4. 2.4GHz 100mW Tx/Rx & 1/3-inch CCD Camera
12 Channel Tx/Rx video system with CCD camera. The camera uses a quality glass lensed SONY CCD camera system.
Included:
1 x 2.4GHz 4 channel Video Transmitter (100mW)
1 x 2.4GHz 12 channel Video Receiver
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
S/N Ratio: 48dB
Whitebalance: Auto
Lens: 3.6MM
Audio:No
Pixel;
NTSC: 510(H)*492(V)
PAL: 500(H)*582(V)
S/N Ratio: 48dB
Whitebalance: Auto
Lens: 3.6MM
Audio:No
Power: 100mW
Input voltage: 8~12V
Weight:29.9g
Power: 100mW
Weight:29.9g
Channels: 4
Channels: 4
HK does not have 1.2GHz systems. Those are all 900MHz.
Ric
Does it mean that the camera and TX/RX support both NTSC and PAL?
So you know how to select PAL?
not the same price trough .
1
2
of 2 Next
