3D-printed drone parts
I have 3d printed a wing part has been flight tested with a MULTIPLEX fuselage (above)
Now I am in a fuselage designing process and I am not sure in the printer axis parts since airstream aligned to Z printer axis layers.
Could somebody help me?
Thank you
  • I have used PLA 3mm white. After testing with ABS, NYLON and PLA, I decided to use PLA because it is biodegradable and not used prints can be refilamented. PLA is too stiff but with correct infill it can become a flexible part able to support required wing lift and drag stress. Next step, fuselage, include will include nose ABS because of the temperture requirements.
    Thank you for asking
  • what material are you using to print the wing?
