3D-printed helicopter blades
A perfect combination of my twin passions, 3D printing and copters! From Hackaday:
If you’re like us, you’ve been infatuated with the small RC helicopter you picked up on Amazon up until the point where it careened off a wall and broke its blades. Now that you’re wondering about what to do with that small pile of plastic, metal, and electronics, why not print some helicopter blades on your 3D printer?
[Taylor] printed these blades on his Utilimaker, but we don’t see why they couldn’t be printed on a Makerbot or other RepRap. The first set of printed blades worked on the top rotor, but they were too heavy when all four blades were replace. The parts were edited in netfabb using a 0.08mm layer height and now they’re working perfectly. As far as free tools go, Slic3r is the new hotness for .STL to Gcode conversion and now that [Taylor] put the files up on Thingiverse, anyone can print a set of spare blades.
  • could we add carbon fiber to the process ?
  • @chris would be truly impressed if they come out balanced :)
  • Not too bad.  Almost as good as the SLS, 0.7mm resolution.  But the nylon used on the SLS printers is slightly more flexible, so the blades would hold up a little better.
