3DR ArduCopter Kits Updated
3689477548?profile=original
3DR ArduCopter kits are back in stock at the 3D Robotics store. The kits have gone through a slight redesign both in mechanical design and documentation. Our new facility in Tijuana, Mexico as well as better suppliers for parts have allowed us to greatly improve the quality of these kits as well as offering them for lower prices. The new frames also look stunning!
The main change to both of the kits is the new arms, the arms are now 40mm shorter which translates to about 10 grams lighter per arm. This allows for the motor cables to be shorter and reduce the weight of the vehicle overall. The motors are no longer mounted through the entire cross section of the arm which caused the old 3DR arms to sink, the motors are not mounted to the top face of the arm providing a better mounting surface. The two frames are significantly smaller and will allow for easier transportation. The arms now come in two colors, blue and black. Each kit will contain 2 blue arms and a spare black arm (3 black arms for the Quad kit and 5 black arms for the hexa kit), this will allow you to build your vehicle in either + or x configuration with the front indicated by a blue arm(s).The center plates on the Hexa-B have been redesigned to accommodate for the shorter arms and large props.
The manuals for both of the kits have been re-written, we took all your feedback and produced a better set of assembly and set-up instructions. 3DR will also be providing a parameter file for these specific frames and keep it current as the code evolves to provide the best possible performance with these frames. The first iteration of this param file should be available shortly.
The full flight electronics quad and hexa kit have been upgraded to APM2.5 .
3DR ArduCopter Quad-C
3689477599?profile=original
Manual
3DR ArduCopter Quad-C Frame Kit     $99.99
3DR ArduCopter Quad-C Frame + Motors Kit     $249.99
3DR ArduCopter Quad-C Frame + Motors + Full Flight Electronics Kit     $449.99
3DR ArduCopter Hexa-B
3689477762?profile=original
Manual
3DR ArduCopter Hexa-B Frame Kit     $129.99
3DR ArduCopter Hexa-B Frame + Motors Kit     $349.99
3DR ArduCopter Hexa-B Frame + Motors + Full Flight Electronics Kit     $549.99
3DR ArduCopter kits will begin shipping today!
  • I'm just curious, but I only see one type of replacement arm available in the store.  It looks like these are the new shorter ones?  If so, will the older arms still be available?  If we need a replacement arm for a 3DR-B quad, do we have to buy a whole new set of 4?
