3DR Radio, First Impressions
P1020223.JPG?width=256
I'm thrilled to report that my radio kit arrived and it works well.  Andreas is likewise happy with his kit.
Writeup here:
http://eastbay-rc.blogspot.com/2012/04/review-3dr-900mhz-radio.html
Fixing the air unit network id:
http://eastbay-rc.blogspot.com/2012/04/setting-network-address-on-3dr-air.html
Thanks 3DR, Tridge, and everybody else that worked in producing this unit!
  • 5v
  • 50 ohms
  • Ok I installed an ESC with a bigger, 5A SBEC. I have the option of outputting 5, 5.5, or 6V to the APM. Which voltage would be best?
  • @Anderew Hmm, thanks for pointing that out. I hadn't noticed any problems but it looks like I should upgrade my ESC / BEC.
    I tried another distance run this passed weekend trying to get to about a mile. The signal got pretty low at around 1500m but I didn't lose the connection. I was able to reduce the ground side noise by mounting my antenna on a tripod instead of the side of my truck bed which is where I had it before. I can post the tlog if you'd like to take a look. I was a little surprised that my 5.8 ghz video didn't degrade at that distance but telemetry did. Video is 600mw with the blue beam antenna set.
    @John,
    I wonder if your ESC isn't quite handling the load? This is a graph of the 2560 CPU voltage for your flight:
    3692407954?profile=originalas you can see, it drops below 4V for a while. That could cause quite a few problems. It really should be close to 5V the whole time.
    Cheers, Tridge
  • @Andrew
    Im powering from a 3S LiPo through the ESC
    @John,
    I checked with Michael, and he does take into account the sequence numbers of the RADIO packets, so that wasn't the explanation. The 5% loss is from the whole flight, and at times the loss is much higher which is a bit unexpected.
    One thing I noticed is the HWSTATUS.Vcc voltage drops quite low at some points in the flight. How are your powering your APM?
    Cheers, Tridge
  • @ Andrew Tridgell, Thanks for the clarification. I was trying to avoid getting the wrong antenna on the module then powering it up.
    Alls ok though, I got the frequencies sorted and should maiden tomorrow.
    All 4 radio's work as described, on the ground, and it looks like other than the three digit ID#, the default settings are spot on.
    Thanks to all involved in this very usefull, and FUN project.
    Dennis
  • @ Andrew
    Thanks for looking at the logs. I never lost telemetry but I was a little worried about the link %'s. I used the Excel method Michael mentioned and charted the signal and noise and I consistently has more noise on the ground than in the air so Ill try adjusting that setup first.
  • *That was with dual 433mhz "air modules"
