Here is my solution to access 6 flight modes on Graupner MZ24 transmitter.
As described in ColinBouriquet's blog, also two swithes has to be activated on MZ24 to manage 6 modes.
The idea is to make the tx send the following to the receiver to activate the 6 modes:
Mode 1: PWM: 0-1230
Mode 2: PWM: 1231 - 1360
Mode 3: PWM: 1361 - 1490
Mode 4: PWM: 1491 - 1620
Mode 5: PWM: 1621 - 1749
Mode 6: PWM: 1750 -
- Activare Base
- Activate Channel set
- Push # 5. Aux 1 (the channel which controls the modes)
You will then see the Select - No - Clr picture
- Activate the chose switch. I have used Sw 5
On the left top of the tx.
Initially, the tx will send these PWMs to the receiver:
Switch far back: 1165
Switch miiddle: 1504
Switch forward: 1817
- Activate Base again
- Activate SW7 to channel 9
- Activate Function
- The movement of the switches will then give this result
You the can access all 6 modes.. Now go to Mission planner an allocate the your chosen modes to the 6 modes you created.
another solution
a different configuration that works:
I set AUX 1 to SW3
AUX 5 to SW6
E.P.A. -/+ travel to CH5 32%
Subtrim ch5 +%34
Prog.Mix.
CH9>>CH5
A +125% B +125%
Offset Y -98%![3702264011?profile=original](https://storage.ning.com/topology/rest/1.0/file/get/3702264011?profile=original)
this is strange because if I don't touch the threshold I got 1105ms instead of 1165, 1505 and 1906 insted of 1817.
then I copy exact your configuration, but the results are compleatelly out of range
I finally managed a different configuration that works:
I set AUX 1 to SW5
AUX 5 to SW6
then E.P.A. threshold to CH5 +/- 32%
Prog.Mix.
CH9>>CH5
A -125% B-125%
Offset Y +4%
this is only way I can get 6 modo correctly switching....
I haven't done anything to thresholds.
What happens when you follow the above instructions?
Have a look at the servo screen in your tx and see what happens when you flip the switches.
Hi
is there any specific thresold for the travel that I have to set?? following your same steps I got different value and finally not abble to switch between all modes...
any suggestion??
