Autonomous UAV Aerobatics Project
here are two notes below that describe the fantastic video demonstration of the MIT Autonomous Airplane Indoor Flying test. Keep your eye on this page for more info in the future."In these flight tests, a fixed vertical landing platform was designed and attached to a concrete pole in the middle of the RAVEN flight space to allow the fixed-wing aircraft to land and perch on the pole. This test is similar to the test performed on January 28th, 2007 except in this test the platform was attached to the wall. This test was repeated number of times and a video shows repeating the vehicle take-off, hover and land sequence twice. In this flight test, the aircraft took off from the vertical landing apparatus and autonomously moved to a location in the northeastern area of the room in the hover configuration. Once the vehicle reached this location, the vehicle was commanded to transition to level flight mode and flew 3 laps around the room. These three laps were completed in about 10 secs (since the vehicle was flying at approx. 6 m/s during the flight). Following the laps, the system commanded the vehicle to transition back to the hover mode and once it stablized itself began its decent to attempt a landing on the vertical landing apparatus. Note that room is approx 8 meters wide."I found this post on DailyDiy.comThe site is fantastic. It is impressive work.
    Those guys do great work, but lest you try to emulate at home, the room vision system they use (from a Hollywood company) costs about $5,000!
