C Compiler for Parallax Propeller Chip
ICCV7 GUI
The BASIC Stamp and Arduino aren't the only microcontrollers out there. The Parallax Propeller chip, as many of you have already discovered, is a more powerful microcontroller. Boasting eight 32-bit processors, it is capable of parallel processing.The major turn off for people to the Propeller was having to write code in the high-level, proprietary Spin language or low-level assembly. There's a good support forum and large object code library, however.ImageCraft has now released a C compiler and IDE for the Propeller as Ken Gracey promised a couple months ago here. You can download a 45-day demo on the ImageCraft website or purchase two different packages (also available at Parallax). The commercial programs are a bit pricey for hobbyists at $99 and $249. Since it's still new, there are only a handful of libraries for it. The IDE interface is a bit clumsy and takes a minute to figure out, but it works. I like the built-in terminal, which you'll have to configure to work with the example codes included (Tools -> Environment Options... -> Terminal tab -> pick COM port & set Baudrate to 57600)ICCV7 for Propeller Features at a Glance: (as listed at the ImageCraft website)
  • comprehensive target support
  • powerful and user-friendly IDE
  • ANSI C compiler
  • optimizations
  • assembler / linker
  • debugger support
  • libraries
  • documentation
  • third party tool support
  • technical support
  • (Additional features, debugger information, etc. listed below)
  • uses Large Memory Model (LMM) to bypass 2K byte limits of Cog code
  • typically 5 to 10 times faster than Spin
  • access Propeller multiprocessing and other Propeller specific features in C
  • write native assembly code and launch it in another Cog for high performance driver
  • built-in terminal
  • support for Parallax's Propellent DLL for program downloading
  • Include libraries such as ASyncIO, VGA Text, etc.
Parallax has promised to begin including C codes in their object exchange, so you can expect to see more useful codes popping up soon.
  • 100KM
    at last !!
    James,
    Excellent post! Good news about the arrival of C. For those who are worried about the pricing, a point of clarification: the combo of compiler and IDE is $99 for non-commerical use, which I imagine is most of us. That's still $99 more than the Spin (or Basic Stamp or Arduino) programming packages, but if it means not having to learn yet another language it may be worth it.
