Ten days till AttoPilot.com goes live
Dean Goedde's highly-anticipated Attopilot, in Pro, Basic and RTL form (estimated costs: $800, $400, $100), will have a proper home in ten days, when his site goes live. [UPDATE: Dean doesn't have an exact date for availability, but as he notes in the comment below, he expects to start taking order in 4-6 weeks, with units shipping around that time.] Lots of background info in this incredibly long thread.
  • I feel fortunate to have guys like Chris and Dean that devote so much of their talent into streamlining autonomous capabilities so that noobs like me can actually participate. I've been flying r/c for a decade but have always wanted to get into the UAV field. Having been paying close attention to all the developments in the autopilot world, only now (with the release of the atto/ardu pilots) do I have the confidence to move forward with my first project.
  • Yes - Arduino is an autopilot, AttoRTL is simply a failsafe. My hat is off to Chris for really breaking some barriers so DIY guys can go nuts a lot easier from the start than the rest of us older-timers had trying to drudge though crud at the beginning.
    Jhon - you don't need FMA CoPilot with Atto RTL if the plane is like a Miss2 or a Gentle Lady... with polyhedral wings
    Just to be clear, we will recommend that most people consider AttoPilot first. ArduPilot is NOT plug-and-play and is very much designed for the DIY crowd. If all you want is a working autopilot you should get AttoPilot. ArduPilot is for people who want to learn about autopilot technology, modify the code, and otherwise fiddle. The cost differences between them are trivial compared to the time differences in the learning curve.
    Maybe someday ArduPilot will be as powerful and easy to use at AttoPilot (if the community contributes to making it so), but we're nowhere near that now. I just wanted to be really clear about this: these autopilots are in entirely different classes.
  • Dean9 but to those 17 gr, you should add FMA Copilot weight, right?
  • Jhon, Cheap Atto and Arduino are for different things, but cheap version of Attopilot has some very powerful features for $100: datalogging of all GPS parameters plus Rx and servo positions to micro-SD card, so you can see your flight in Google Earth later using a provided application that converts the LOG.txt into a 3D .kml file, PLUS has a telemetry output pin, so with your modem you can have live moving map on your laptop. Plus, cheap Atto is only 17 grams including the GPS (everything is 17 grams), and is only 1"x1"x0.4" including the GPS as one tiny shrink wrapped package (see http://www.rcgroups.com/forums/attachment.php?attachmentid=2062712).... You really can't compare it to Arduino, as they serve different purposes. Also the cheap Atto has "loiter lock" function, so you can trigger it to hold the plane in a circular loiter whenever you want.
    Attachment browser: IMG_3879.jpg by dmgoedde - RC Groups
  • so ardupilot its way better, 70$ more cheap, and probably more lighweight.
    well, no GPS included for 30$, but still better in my opinion,
    The cheapest AttoPilot is just return-to-launch. No programmable waypoints. ArduPilot has programmable waypoints.
  • but whats tha advantage of the cheap version AttoPilot over ArduPilot ?
  • I think we are talking about nuts and bolts of "how to", which is the point of DIY drones. There is nothing to brag about on my results, as they are far from miraculous if you consider the amount of time and effort I have in it all... not a self-congratulation. If you don't have (or can get rid) of all responsibilities in life except making an autopilot (wife, job, kids) and work it 18 hours a day, you should get some pretty neat results.
    As for "missed waypints" you bring up a good point... what to do to prevent plane from looping back and making an ugly path around the sky as it tries for the waypoint over and over.. I'll just tell you what I do, and intellectual property be damned (it is not a big deal for this topic)... I set TWO "satisfy" distances... the outer distance is rather generous, not a huge 1/10 mile of a Pico (around 160 yards), but something reasonable like 50 meters.... very easy to hit. If plane gets inside this distance, then a flag is checked as TRUE, and the autopilot starts to track if the distance in each navigation iteration is decreasing (converging) or increasing (diverging) from the waypoint. when the distance starts to diverge, then that waypoint is truly checked off as "done" and the next WP is loaded as current target. A problem arises if as the plane is approaching the WP very close (like 5 meters) the heading error can get very large at the last instant and the plane will do a little wiggle. The wiggle is not good because what if you want a NADIR photo of the ground? So what I do is have a smaller "satisfy" radius of say 10 meters, and inside this circle the roll angle target is locked. this way the plane prevents the last second wiggle. Also, I highly recommend you check out the 4Hz and 5Hz GPS, plus you can do interpolation of coordinates between GPS updates for a finer positional estimation.
  • By contengencies I mean what to do if GPS lock is lost, or GPS dies, or a sensor fails, or gives data that is outside of a reasonable range... I think your Kalman filter can do these things as far as reasonableness of the data goes... but the GPS lock lost is important to handle, and is not part of a data filter, per se.
