A new OSD for FPV - PlayuavOSD
Hi,I want to share a new OSD - the PlayuavOSD. It is new but not totally unfamiliar. It is created by integrating a variety of excellent open-source projects. Many thanks to the developers for their efforts and dedication.
This project is licensed under CC 3.0 BY-SA and GUN v3. You can find all information about this OSD at http://www.github.com/Playuav/playuavosd, including the source code, the schematic diagram, and the configuration tools etc.
Inevitably there will be bugs and improper designs. But as an OSD, I don't think it will cause crash:-). Though most functions have been realized, there is still a lot to do, such as the implement of UAVTalk and DJI CAN. If you are interested in it, please share your opinions and suggestions. Thank you.
Config Tool download here. Manual download here.
Configuration video:
  • Hi, I've work with Tom on another firmware with altitude relative and airspeed instead of groundspeed. Everything is ok now and tested.
    Tom said he will add some option to choose in config tool if people prefer alt absolute or relative AND groundspeed or airspeed.
    But for must people, it will be ok with this version.
    Tom must publish it soon on his link above (begining of this thread)
  • I would love to see a terrain vs AGL altitude read out with look ahead, maybe even in the form of a small graph.
  • Hi Pavel,
    I've ask Tom to make to change if possible
    1/ choose display of airsppeed or grounspeed in config tool
    2/ choose display of relative altitude instead of sea level.
    3/ I ask Tom to rename video in 2 to video in 1 too.
    4/ did you see the last screen number 3 availbale since yesterday ? really really cool  !! Big thanks to Tom
    I make some screenshot under Xplane HIL mode of the 3 panel available from playuav osd
    Screen 1
    3702108243?profile=original
    Screen 2
    3702108268?profile=original
    Screen 3 (with waypoint and real bearing - very usefull : herre my waypoint are very far from home some they are not so big but normally it's absolutely perfect )
    3702108034?profile=original
    Sure, there some minor bug but it's so pleasant to have minimsod alternative like this Project Playuav osd and Alceosd.
    Having 2 input on the same board for front and rear cam for example is so brillant idea !
    Thanks to Tom !!!!
  • Hi pavel > I've plug the playuav osd on a pixfalcon without problem but just need to understand that video in 2 IS video in 1 ! So my advice try to put your cam on video 2 first.
    https://www.youtube.com/watch?v=Hq1Gr8ZOZno&feature=youtu.be
  • Hi Pavel,
    I don't have a Mini APM2.72 board and even have not heard about it before. But I think it should be compatible with APM firmware. In this case, it must have serial ports which are used to send MAVLINK to accessories like radio, OSD. The communication between PlayUAV OSD and FC is through serial port. Banggood should have provided you the serial cable together with the Mini APM. And you should have received a cable from goodluckby to connect APM with OSD(5 pins for APM and 6 pins for Pixhawk). Make sure that the VCC and GND are connected correctly, then pull the wire out and connect it to the right port. The LED on the OSD board will be turned on. Meanwhile, if you do the RX and TX connection correctly, OSD will receive data. You’d better refer to the schematic or the manual.
  • @Raphael, 5V from the FC has no problems. Some uses wish the OSD needs to be able to be powered by 2-4s lipo. Maybe we should do it in the next version.
    @HLiu,
    1)There is an item "Load default params" in the file menu.
    2)If the NTSC camera does not work, please post an issue at githbu. Your feedback would be much appreciated.
      https://github.com/PlayUAV/PlayuavOSD/issues
    3)The idea of F16 HUD sounds exciting. We can do it in the future. Currently we should focus on the features and bug fix. Thank you for your suggestions.
    PlayUAV/PlayuavOSD
    A Graphical OSD for FPV. Contribute to PlayUAV/PlayuavOSD development by creating an account on GitHub.
  • Any plan to support F16 HUD ?
  • Please advice how to:
    -reset to factory default
    -change video mode to NTSC
    Thanks !
  • Hi Raphael, the OSD can work with Telemetry using Y cable. I haven't tested it with storm32 Gimbal. There should be no problem. However, please do be careful with the voltage of OSD because the MAX7456 chip supply voltage is 4.75V-5.25V.
  •  @gasper kolenc
    The current firmware supports APM/PIXHAWK, but is not compatible with other FCs yet.
