This night flight video looks clear enough for my FPV night flight next time.
Day FPV flight with ACM2 tri, like I owned a easy to drive private helicopter for air traveling.
Especially the RTL function consolidate the FPV flight safety when wireless video or RC control was lost.
Swap servo's brush moter cable and VR pin 1 & 3 might work theoretically.
Frame mode setting shouldn't affect tricopter, no matter what mode I set, my tri flies well.
Hopefully it's helpful.
Thanks.
-Cliff
can you help us to solve the problem
http://diydrones.com/forum/topics/tricopter-yaw-servo-reversed?page...
thank's before
the setting of CLI (+, x, v)
how if i reverse the servo by hardware? (swap potensio & motor cable) it is will work?
becouse to difficult if i change the servo mouting :(
Answer to RJBK,
I used to try to modify source code to reverse tri servo, but didn't get it work.
I decided to change servo mounting direction for quicker setup.
Tri setup has nothing to do with frame type from my understanding from the code.
2 CCW propellers and 1 CW prop were used as tri's optional type setting.
-Cliff
amazing,
I'm trying to 3C as well.
but my problem is always turning heads.
is it possible to reverse my servo position?
what's your frame mode using?
and is use ccw prop for all motors.
