3689600537?profile=originalI just got a Quanum Nova, which is a fantastic APM-powered copter that in many way outperforms the DJI Phantom for less than $300.  Although it's capable of full autonomy, just like any other ArduCopter, the one thing it's missing for easy field mission planning and DroidPlanner compatibility is telemetry.
In this great tutorial, Jean-Louis Naudin shows how to add that:
Here an explanation for connecting the real time telemetry to the CX-20 or to the Quanum Nova
The telemetry port is located on the I/O board of the APM (the second board at the bottom and pluged to the main CPU board) where all the I/O plug are connected. The telemetry port is fully compatible with all the telemetry transmitter (3DR and all the compatible boards) and also with the Bluetooth boards commonly used with the APM boards.
alt text
Below the pinout which shows the telemetry port I/O (back to the I/O board).
Note from the comments: depending on which radio you're using, you may have to reverse the TX and RX lines. Dmitry in the comments reports: "You must connect RX from the radio to TX on the APM! And vice versa for Radio TX. So I've changed green and yellow wires and it works!"
 alt text
sold 4 cables on the telemetry ports alt textthen protect the connections with hot glue alt text
Check the functioning alt text
The 4 pins telemetry plug is installed on the back of the fuselage alt text
Check the connection (at 57600 baud) with the mission planner or the Droid Planner 2 alt textalt text
Then, you may enjoy to use the telemetry... alt text
NEXT CHAPTER: Full autonomous mission with the Cheerson CX 20
    Dmitry, I've edited the post above to include your comment. Thanks!
  • Seems it's all about new ver MP or something else...
  • Wow.
    PLS fix this post cause I've killed about 3 hrs to fix my 3rd 915mhz telemetry.
    The issue was that you must connect RX from the radio to TX on the APM! And vice versa for Radio TX.
  • Thanks a lot Jeff.
    That was the solution!!! You made my day!!! :-)
    Tobi
  • I had the same issue.  You have to solder directly to some tiny pins on the board. http://www.rcgroups.com/forums/showthread.php?t=2112759&highlig...
     Make sure tx is going to rx and vice versa.
  • Hi,
    I hope someone can help me to get my 3DR Radio work with my Quanum Nova. I tried everything I found in the web, but with no success.
    - updated Firmware on both radios
    - set baud rate on 57600
    - selected right com-port
    - LEDs solid green
    - connected tx to rx
    - no USB connected, APM powered with ESC
    - radios connected, can change settings on both via mission planner
    But when I click on connect it does not connect via MavLink (Time out)
    I think it must be a problem between APM an Air radio connection. I did the soldering as shown above. I messured the voltage between 5V, RX, TX... they show different voltages, so I think I did the soldering right.
    Can anyone else please messure the voltage an each Pin? Just to compare the output.
    Maybe there are different types of 3DR radios? Do I need a special one for the Quanum Nova Board (APM 2.5.2)??? I bought a radio for ATM 2.5 / 2.6
    Hope someone can help me...
    Thanks a lot.
    Tobi
  • Wow!  Just what I needed.  If only the person at HK's chat line had pointed me to this video, It would have solved a lot of hassle.
    Thanks!
  • Check this video out.  If it doesnt answer your questions please be more specific and we can help.
    https://www.youtube.com/watch?v=jnhXSI2sTa0&feature=youtu.be
  • I need some help - hopefully someone that has experience with this machine.  I bought one from HK without a radio.
    See my earlier post in the "uncategorized" section.
  • This method didn't work for me. On my QNova from HK. I used the method described by sloth2005 on RCgroups discussion.
    My Bluetooth works with droid planner 2.0... See my post http://www.rcgroups.com/forums/showpost.php?p=28753951&postcoun...
