IOBoard Let's make it better... We need testers...
Awhile ago we made first translating program for IOBoard and since that people have been using it as it was and/or modifying its open software. Now that we have more and more devices supporting FrSky telemetry, converting becomes more fun.
So let's make it. Current roadmap for IOBoard is:
- Have full support for MAVLink/FrSky conversion
- LED driver with configurable patterns
- OpenTX, er9X support
- TLD-02 display support
- Updated Configurator
Currently tested features on Taranis radio:
Heading, Temperature 1, Temperature 2 (shows satellites/fix type), Armed/Disarmed and Throttle values,
Lat/Lon, Altitude, Voltage, Cell volt (avg), Speed
jD-IOBoard can be found from jDrones store
Latest MAVLink/FrSky software is IOBoard_FrSkyMAVLink.v03a
software can also be found from arducodes repository at google code
Let us know how it works and if you have ideas, post it on..
Try this
Latitude and Longitude of a Point
http://itouchmap.com/latlong.html
@ LTMNO
No, of course the numbers don't 'match' - they're not in the same units are they.
Take another look at my post.
MAVLINK sends data in degrees.decimal degrees
The latest FrSky_Mavlink program will transmit the data as -
degrees/minutes.seconds/decimal seconds (note the deliberate use of the decimal point)
My example (I thought) showed exactly what this meant.
Let's turn to your data as shown in your post above and do a little conversion:
MP GCS Lat = 43.91883 or 43 degrees and 0.91883 decimal degrees.
0.91883 decimal degrees multiplied by 60 (i.e. convert to minutes) is 55.1298 minutes
0.1298 decimal minutes is 07.788 seconds
With rounding, because there are only 2 decimal digits displayed on your screen, and putting these values together in the new format will give a composite value of 4355.08
QED
Try it with the Lon data and see what you get.
The Alt value is more of a puzzle.
On my Tx the altitude value displayed matches the altasl value shown in MP and that agrees with the value shown on the local Ordnance Survey map. The data your pic shows has altasl at 261.88 but the value from the IO board as 1.08/1.12
Now the value shown by the Tx display will depend on the data picked from the telemetry stream according to the programmer (the excellent Mike B in the case of ersky9x); OpenTx may have picked an alternative 'alt' value e.g. the 0x01 data rather than that given by 0x10 from the FrSky data stream. We need to define what it is we want to be displayed.
Hope this helps.
LTMNO FrSky uses different format so you cannot compare them directly with MissionPlanner coordinates. You need to know how to convert them to be decimal values. FrSky uses minutes and seconds format.
Hi Simon.... perhaps I don't understand how to read the Lon/Lat?
I am only comparing the values that are on the screen depicted above. They are not matching... however... perhaps i am not understanding the translation from IOBoard to FrySky?
43.9188384 != 4355.08
-79.8005184 != 7948.02
43.9188384,-79.8005184 - This value in fact is the coordinates to my home.
@ LTMNO
Please explain why you think that Lat/Lon are incorrect.
Oh yeah i forget Modes :)
Yes there are currently debug feed running from Miso/Mosi pins that you can hook up with FTDI cable. I will add more functionality on that later but now it shows atleast most important values and you can check that IOBoard will receive real values from APM/FC. If MAVLink rates are not set correctly most of those values are 0000.
I have hardware for external display (GLCD 128x64) too but currently no software for it. Anyone willing to help on that? I plan that to be replacement for FLD-02 display as all it's screens are Fixed and we need to change their data :)
Not sure if this was what you were looking for regarding OpenTx Telemetry Values
Each field can be one of the various available parameters, of course the corresponding sensors and/or hub must be installed in the model:
Ignore my previous posts.. now that I have re-read your initial post, I see exactly what you are transmitting from the APM to IOBoard to the FrySky Receiver. All that information is being transmitted to the Receiver.
It seems that the follows values are correct..
Sats
Fix
Modes
Armed
BattVolt
Hdg
And the following are incorrect...
Lon/Lat
Alt
I color matched the FTDI Capture to the APM Screen. Hope that makes sense? Midnight here, will take a look again tomorrow.
Cheers.
Values that are running and known to be correct:
Accel - X, Y, Z = Accelerometer values, -+ values
Temperature 1 = Flight controller internal temperature, Celsius
Temperature 2 = Visible satellite count and GPS Fix style, 2-3 digits where LAST digit is fix status 0-1 No fix, 2 2D Fix, 3 3D Fix. FRONT digits are amount of satellites. For example "63" = 6 satellites, 3D FIx or "103" is 10 satellites, 3D fix or "32" = 3 satellites, 2D fix
Heading = Your current compass heading
RPM = Armed/Disarmed status and approximate throttle value when armed. 0 = Disarmed/Motors off, Values between 1020 - 1960 are shown when motors are armed and throttle position. Number represents pulse width so for example around 1500 is middle throttle. This value is NOT exactly same what Mission Planner might show for your throttle channel as we need to use special scaling made by FrSky but it's close to it. Accuracy is -+30 uS.
Altitude = Altitude detected by your flight controller (works on tabletop tests, not confirmed on real flight yet. Anyone??)
Lat/Lon = GPS Latitude/Longitude details with N/S, W/E indicators
Time = Sec/Min/Hours since last reboot of IOBoard
Things that needs to be fixed/confirmed are:
Voltage = Battery voltage. It seems to work but startis drifting after awhile.
Current = It's seen by IOBoard but not forwarded correctly
Fuel Level = Seen by IOBoard but not confirmed yet
Speed = Seen by IOBoard but not confirmed yet
LED outputs and patterns. Currently still untouched. Work with these begins after FrSky converter is ok.
There seems to be huge amount of extra parameters that Taranis and er9x style radios can show, anyone happen to have simple document of these?
Magnus I have not looked OpenLRS lately but after whole base software is done for IOBoard adding additional protocol is not too difficult. Can you point to some OpenLRS protocol specs so I can take a look at it.
Happy to hear that it starts to work for all of you. We still need field testing for speeds and altitudes etc to be sure that they work as expected.
8
9
10
11
12
of 12 Next
