Aerodynamic efficiency
As everybody is working on ways to improve electronic response I thought it was time I did a little work to see what can be done beyond the electric motor.  Coanda and Bernoullis effect put to good use.3689416485?profile=original
  • So .... this is the way the gain of efficiency is achive.
    I find this an interesting combination of DIY and hands on physic concepts.
  • Just to explain the way in which air is drawn towards the center underside of the hull. As the laminar air flow produces low static pressure the flow of air is then disrupted to separate and create pressure recovery on the underside.
  • Bernoullis effect induces low pressure across the top surfaces and the coanda effect draws the downflow of air towards the underside of the hull creating a slightly higher pressure. As the lift is force x area then you don't need that much of a pressure differential to create some worthwhile extra lift.
    An interesting bye product of all this could be a new concept of control. Consider this, if we want to move to the left say, then that would start with a bank to the left. But if we use another aerodynamic device known as a Gurney then that increase in thrust from the right side could also produce a sideways force that would push in the desired direction without all of that bank angle.
  • Yes I did test without the foam. and it gave the normal figs. that I have seen on the previous FMC designs.
    The model balances exactly in the center of the X , note the position of the batteries (3) at the rear.
  • I am trying to imagine the propelor generated air flow and the way the foam use and change that air flow to any type off beneficial added effect.
    Any idea .....
  • My next line of thought is to have some code that would give me a three axis camera stabilisation output that uses the 4x output from the IDG-500 - less than 1 us resolution. And then we would all have the best thing out there by miles. I do have a new camera mount design that uses the Hitec HS 5087MH 7.4Volt servos. By running the servos in continuous rotation with the pot locked up we get a fantastic stick response where the Camera mount moves faster as the stick moves away from neutral and slows down and stops when it returns to the neutral position. The camera stays in that last position and still stabilizes normally. This is simply the most natural way to steer a camera. I don't do code but I guess we have a few out there who could do this and take us to the very top.
  • Now!  What is this ?
    The CG seems to be off centered by the camera !
     How does the Coanda and Bernoullis effects operate the magic here?
    I simply love this one.
    Wayting  ... for more ... please.
  • It is flying very well Chris. I have only played with the PIDs for a couple of flights but it is as good as anything else that I have used thus far. I did have the side cut outs fully enclosed and that did give a fantastic level of lift efficiency but it would not stabilize properly as the pressure distribution below the hull was not really controllable.  Having the props below the arms is also an advantage. Profile drag being a square law. Based on Holgers lift figures, one motor should incur 10 amps at 16 volts to lift 1.25 kilos. However this was drawing only 20 amps total to lift 5 kilos at 2 feet off the ground and only 30 at 7 feet off the ground. I should have the all up weight at around 4.2 kilos in the end. 5 kilos and above is a real nightmare with battery life even at this efficiency level.
    Wow! How does it fly?
