Several year ago, I wrote a booklet entitled Aerodynamics in Plain English.  Last week, I convert it to a PDF EBook.  I embed the entire book on the front page of my website for viewing (please scroll down to the end of the page).  There is also an option to purchase the PDF version if you would like a permanent copy.
My webpage is located at the following url:
http://www.hanleyinnovations.com
The following topics are addressed in Aerodynamics in Plain English:
Basic Concepts
Definition of aerodynamics and fluid dynamics.  Find out why aerodynamics is a difficult topic of study.
Forces on an Airplane. Why Does it Fly?
Introduction to forces acting on an airplane. Explanation of the role of the lift, drag, weight and thrust forces as related to flight.
What is Density?
Definition of density; Comparison of air and water densities; The  relations between lift, drag and density.
What is Viscosity?
Definition of viscosity;  Introduction to the role of viscosity in aerodynamic drag.
What is Compressibility?
Definition of compressibility; Speed of sound definition; Mach number definition; Prandtl-Glauert rule.
What is Pressure?
Definition of pressure; the relations between lift and drag and pressure; conservation laws and pressure.
Non-Dimensional Numbers
Some non-dimensional number in aerodynamics include the lift, drag and moment coefficients in addition to Reynolds number and Mach number.
Reynolds Numbers
Definition and importance of Reynolds number. Table with sample calculations of Reynolds number.
Lift, Drag and Moment Coefficients
Definition and calculation of lift, drag and moment coefficients. Importance of consistent units examined in calculations.
The Wing
Role of different shaped wings; Definition of induced drag; Introduction to tapered, sweptback and delta wings.
How Does a Wing Generate Lift?
The relations between conservation of mass, conservation of momentum, streamlines, Bernoulli equation, pressure and lift are discussed in this section.
How Does a Wing Generate Drag?
This discussion about the generation of profile drag includes the role of boundary layers, transition points, adverse pressure gradients and laminar flow airfoils.
Airfoils
This glossary of terms define the parts of an airfoil and characterize different types of airfoils.
How to Pick Airfoil for Wings
How to use the lift and drag polar plot, the lift and moment versus angle of attack plots to compare airfoils and choose the correct one for your application.
Designing and Testing Airfoils
This section introduces inverse design and airfoil modification concepts for designing airfoils. An overview of experimental and computer testing of airfoils is presented.
Considerations for Makers
Further consideration for builders examine the role of airfoil thickness in the design of wings.
Definitions
A glossary of several terms in the field of aerodynamics.
References
Books and software for further exploration of aerodynamics.
Comment by Olivier on March 5, 2016 at 1:17pm
Outstanding, and thanks for sharing!  Your Stallion 3D CFD software also looks top notch.
Comment by Patrick Hanley on March 5, 2016 at 1:38pm
Hi Oliver, thanks for your kind words.  Have a great weekend.
Comment by Darius Jack on March 6, 2016 at 7:08am
Thank you Patrick.
Since 99% of us fly multicopter personal drones, could you append your Aeerodynamics in Plain English with diagram to illustrate lift, drag, thrust and weight force vectors in case of multicopter, VTOL.
Drag and weight force vectors pointing down on take off (VTOL),
lift and thrust force vectors pointing up on take off (VTOL).
Comment by Patrick Hanley on March 6, 2016 at 11:24am
Hi Darius,
Thanks for your comments.  I will keep this in mind when I revise the EBook. Hope you are doing well.  Best wishes.
Comment by Francisco K on March 7, 2016 at 4:58pm
Thanks for sharing it with us Patrick, I will bookmark your website for future reference. Now I've studied Basic Aeronautical Knowledge as part of my PPL training, so most of it, won't be Chinese for me. But I have forgotten some of it, so reading your Ebook shouldn't be a challenge for me.
Comment by Patrick Hanley on March 8, 2016 at 7:36am
Hi Francisco, thanks for your comments and for reading Aerodynamics in Plain English.  Best wishes.
Comment
