As part of my plane to create a simple, solid Arducopter frame, I have had a number of parts laser cut in 2mm 6082 aluminium from the original Arducopter frame design by the DIYD team.
The parts have come back a little more "bashed up" than I expected, but apparently that's normal, they just need a clean-up with something abbrasive.
I had trouble opening the DXF files in the SVN. In the end I opened them in Microsoft Visio, saved them as Autocad files and then exported them back into DXF files from within Autocad after I tweaked the legs etc not to need the dome. The laser cutters seemed to need the DXF files in the 2004 format attached.
I can't verify anything fits (they've just arrived and I'm in the office), but for those feeling brave the DXF files I used are attached for anyone that wants them.
Cheers!
That frame looks great. Can't wait to see it looking arf! If you need any nylon spacers, hex mounts or screws please let me know I'm sure I will have a little something in stock that should work!
Will you be bringing this with you to the UK fly in June? Would be great to see it first hand!
Regards
Martin.
www.buildyourowndrone.co.uk
@ Gary: Interested to know how that works out Gary, I have no experience of that material. Was considering Carbon Fibre possibly at some point in the future once I have ironed out any wrinkles.
@ Ken/Ethan: That sounds very Pimp my Quad! Hmmmm, anodized... That could be good!!!!
@Russell: Sorry I don't know yet but will update ASAP
What is the weight of your all Aluminum Copter skeleton. I'm working on a Foam and Carbon arrow shaft frame. Should be about 175 grams.
I was thinking about the plastic screws: one benefit would be that they would hopefully break and relieve pressure before any of the metal bends. But then, they may break too often and the aluminum remains well under it's bending point.
UPDATE:
I ran down to the post room and weighed one set consisting of: 2 main boards, 1 carrier, 4 motor upperas, 4 motor lowers, 1 batter holder, 8 legs and the total was 212 grams. I have nothing to compare that to until I get home...
Ethan,
I still have my Arducopter kit sitting at home ready for a build (hopefully this weekend) so I was going to have a sit down and use the plastic kit screws for now and then upgrade to aluminium if/as required. Spacers etc will be plastic and I may need to insulate the carrier boards for obvious reasons.
Weight wise I have no idea! When I get her anywhere near finished I will throw her on the scales! I have the original parts for comparison.
