The blue line is what the model thinks it should do, the green line is what I actually did when a human was steering it.
From Hackaday, a great project showing how to create a self-driving R/C car that can follow a complex road pattern without human intervention. It uses TensorFlow running on an Intel processor onboard. Click through to read more about the importance of polarizing filters and how to implement TensorFlow.
Unexpectedly they have eschewed the many ARM-based boards as the brains of the unit, instead going for an Intel NUC mini-PC powered by a Core i5 as the brains of the unit. It’s powered by a laptop battery bank, and takes input from a webcam. Direction and throttle can be computed by the NUC and sent to an Arduino which handles the car control. There is also a radio control channel allowing the car to be switched from autonomous to human controlled to emergency stop modes.
They go into detail on the polarizing and neutral density filters they used with their webcam, something that may make interesting reading for anyone interested in machine vision. All their code is open source, and can be found linked from their write-up. Meanwhile the video below the break shows their machine on their test circuit, completing it with varying levels of success.
the green line is what I actually did ??????
when a human was steering it."
when you split the animated gif into individual image / video frames with EzGif
http://ezgif.com/split/d29c7f3b5f.gif
you have impression this video / animated gif has been postedited
gif image data extracted by EzGif
File size: 3.29M, width: 311px, height: 251px, frames: 145, type: gif
but you can clearly see frame 0 is repeated 10 times
frame 1: 3 times
frame 2: is missing
the last frames are the following
588,
592,
597,
601,
604, repeated 5 times
frame: 577
you can clearly see, algorithm requires some modifications (more training does nothing for better),
since obstacle (right boundary of the road) is too close to the right and obstacle-free horizon is far to the left
alike control error can be seen in frames:
544, 547, 535, 522, 468, 364, 369, 355, 340, 322, 311, 136, 131, 127, 122, 107, 103, frame 0 (???)
frame: 202 - human error
I am really sorry, but this implementation of the algorithm has a great potential to crash this model car 10-20 times.
It's quite clear, algorithm adopted fails to look for the furthest clear horizon not to say about any prediction adopted to follow in advance road boundaries turning left or right.
Jack, Tensorflow is using a library of past images to train a neural network, so that the vehicle is driven by decision based on an Artificial Intelligence system that is quit close to the existing self driven cars.
This example may look like a glorified line follower that you can be build using simple analog comparators, but the fundamental difference lies in the backend that is a totally a new concept.
Tensorflow, or any well designed neural networks have the potential to control a racing drone and win a race once we can get enough processing power airborne , and cleverly trained a drone steering dataset.
What it's probably doing is recalling the steering commands from a library of past images rather than interpreting the position of the lines. Tensorflow is the new SURF. Despite getting a lot farther than mistaking his laptop for a toaster, he is not in Inc Magazine's top 30 under 30 so no buyout.
Thank you for interesting input.
May be TX1 is good to go when you intend to fly that thing, but Intel is robust while it moves on the ground:-)
Yikes. Intel it is!
And check the date , october 6
I'm leaning more towards the Tegra
The cost of i5-NCU and Tegra is almost same. Which one is your recommendation or like for this purpose?
Excellent Blog: They explain in detail how they trained their vehicle.
Who will train a racer drone using the same technique ?? I am tempted...
It requires a lot of onboard processing: Inten NUC – The raspberry pi doesn’t really have enough power and is arm based. An x86 based processor like the i5 in our NUC is much easier to use for machine learning purposes. The exact one you use doesn’t matter.
