This could be a good one. Coming to HobbyKing in a few weeks, and sure to be inexpensive. I can only hope the ridiculously chubby looks means lots of interior room!
Little more info an the Eagle wing:
And yes it got spares.
Strong EPO built, durable. Made by the same factory as Skywalker.
Length: 940mm
Wingspan:1500mm
Wing Area: 24.8dm2
Wing Loading: 33.4g/dm2
Weight (approx): 700-950g
Requirement:
4ch Radio
4 x ES08A(or ES08MA) servos (for 2x Aileron, 1xElevator, 1xrudder)
2200-3300mAh 3S or 4S Lipo Battery
Motor: 2215 KV1100
Propeller: APC 7060-8060E
ESC: 25-35A
Can you post some specs on the Eagle Wing? Please.
"Pusher Star is specially designed for RC beginners by RICCS Electronic Technology Co., Ltd...It is an advanced trainer aircraft for the beginners. As the airplanes always are fell off becuase of the hobbists unskilled operations. So we use the stronger EPO material as the mainstay. We consider the most of the R/C enthusiasts always like flying and communicating with other RC hobbists outdoor, so we design a kind of demountable main wing. You can conveniently put it into the boot of the car. It can be easily inserted into the two side holes of the fuselage. Meanwhile we can offer the training mode radio system so that the R/C hobbyists can relaxedly and fast learn to fly from the trainer, enjoy the fun of the flying.
The location of battery is under the cockpit of the airplane. In orde to replace the battery conveniently, our cockpit is pasted with magnet. You don't worry the battery fall off the cockpit. If you still worry, we suggest you paste both the cockpit and the fuselage with the scotch tape again.
If you are a enthusiast of aerial photography, we specially reserve a position for installing the camera. That you need change the tawny cabin for hyaline cabin so as to enhance the its sharpness. In order to enhance the withstand wind performance, we specially select 6mm in diameter carbon rod to connect the main wing. In this way, under 5 level strong wind, you don't worry the main wing will be broken off.
We use a single bulgy anhedral wing section for the main wing. The features of the wing are good stability and favorable glide. The main wingis used middle monowing so that the airplane can do various actions more flexibly. You can loosen the remote control after the airplane enter into the appointed air line. The airplane can still fly free. Of course, Riccs company doesn't suggest you operate like this. If you do like this, the loss caused by it, any responsibility won't be undertaked by Riccs.
It is a expected product for the beginners. Believe it's wise to select it.
Product Specification:
Material: EPO
Propeller: 8*6
Length: 941mm(37.05inch)
Wingspan: 1017mm(40.04inch)
Flying weight: G(oz)
Net weight: G(oz)
Product Parameter:
Motor: 2822 KV1000
Out-runner brushless
ESC: 20A
Servo: 4*9g
Battery: 11.1V/1300mAh/15c
Balance charger: 2-3s
Radio: 2.4G 4CH TX/6CH RX"
1
2
of 2 Next
