I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
Maybe yours go to my adress... :-) as you know.... luck changes all time.
I´m sorry Jani, i will not ask about products here again.
I registered my mail to receive back in stock notification but do not received info about this batch chandan "lucked" to buy.
In generally there is big silicon chip shortage in world currently and it affects on all electronics assembly. Jordi and others who are doing electronics are fighting with this issue every day and they try to get parts as fast as possible. I'm sure that there will be new IMUs and others immediately in shop when they receive parts for those.
@Max well you also need level shifter for I2C which is a more complicated than just 5->3.3v regulator thing. SFE do have level shifter boards too but I never tested those (even i have 2 on my drawer)
So you either get one maggy + level shifter from SFE or wait a bit until DIY have them in stock. And meanwhile we can prepare code changes so it will be safe to use again.
.... the store do not accept back orders? when it will be in stock?
And if someone wonders why our repository revisions are running so fast. We are working on wiki pages and every update on wiki also affects main repository revision number. So since r138 in reality there has only been 4 updates to main code.
Software is really unstable for next 2 weeks or so due we are doing rather big architectural changes on core code. So be carefull with it, I just broke my quad on yesterday's test :)
Also almost every new software release need full EEPROM initialization so all your settings will be wiped out on every upload.
If you want to get rather stable and nice flying software, pull out revision r138 from repository. But I would suggest to hold a while untill we get our first public Alpha release out.
And about CPU power, currently we use around 30%-50% of our CPU power where DCM calculation takes most of it. Everything else is rather simple to calculate and they are a lot less demanding computations. If there is a need in future to grow computation speed on our boards, Atmel already have faster CPUs but for now we will stay with well known Arduino environment. But sure, we do keep our eyes open all the time.
http://www.st.com/stonline/products/families/evaluation_boards/stev....
This board seems to have more hardware and processor that the Oil pan.. or not?
37
38
39
40
41
of 82 Next
