I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
@Peter, there are still a lot fine tunings to do on angle calculation. Strong winds are still difficult for current software. Remember, it is not yet even "released officially"
Any other suggestions?
Peter
Next batch will be a lot bigger than beta batch was so there should be stock for awhile, If not we create more.
@Max, you can start playing with P and I values. Change one value at time and try flying. Don't do any huge changes especially on I value. I is affecting most on leveling. P mostly on general stability so that would be best to start with. You can use your ESCs to power RX or what ever. Just connect their GND lines if nothing else.
Frames are doing fine. Currently doing final modifications to them and hopefully production starts in 1 week or so. Not any major changes, overall feedback from it has been great.
Changes/Mods:
- Dome Arches will be 5mm taller to provide a bit more "headspace" on top of upper carrier plate
- Landing Gear FINs, 10-15mm taller to provide a bit more space under belly, also a bit wider
- Motors will be included on next batch
- ESCs will be included on next batch
- Propellers will be included on next batch
- There will be additional Arms set without cable holes
- Extra screws for mounting motors for people who are not using official ArduCopter motors
- Few other items will be swapped between packets
- New retail box that can hold all electronics, motors etc
- Double sided Power Distribution board with plated trough holes to make assembly easier
We are also looking ways to change P-Distro board to different. As a wire harness and then P-PCB would be replaced with another PCB that can have LED drivers and maybe even that UBEC on board.
Those are main changes on next set. Also there will be full list of spare parts available along with CrashKIT for people who are able to crash their easy fly and stable quads :)
18
19
20
21
22
of 82 Next
