I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
And here's the impressive work of the AeroQuad team:
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
Here's the announcement from the AeroQuad team:
ArduCopter - The Full Featured UAV Multicopter!
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature ListSoftware Roadmap
- 6 Degree of Freedom IMU stabilized control
- Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
- GPS for position hold
- Magnetometer for heading determination
- Barometer for altitude hold
- IR sensor integration for obstacle avoidance
- Sonar sensor for automated takeoff and landing capability
- Automated waypoint navigation
- Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
- On board flight telemetery data storage
- Mounted camera stabilization capability
- Wireless command & telemetry for long distance communication
- Capability to fly in "+", "x", hexa and octo configurations
- Battery level detection
- User configurable LED flight pattern
- Capability to use any R/C receiver
- ArduCopter Configuration and Ground Control Software
- Realtime graphs of flight data
- GUI for configuration of PID and other flight parameters
- On Screen Display integration
- Waypoint programming using Google Maps
- Mixertable view to auto configure "+", "x", hexa and octo configurations
- Initial baseline using Jose Julio's v3 software
- Provides absolute angle PID flight control
- Obstacle avoidance
- Waypoint navigation
- Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
- Emphasis on developing new capability into easy to use C++ libraries
- Integrate user defined EEPROM storage capability
- Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
- Integrate AeroQuad Configurator for external software configuration of ArduCopter
- Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
- Integrate AeroQuad rate PID control
- Integrate mixertable configuration for multicopter configurations
- Integrate AeroQuad camera stabilization
- Integrate I2C motor control
- Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
What I did today was just having throttle at 0, threw it up in sky in various different angles, gave throttle so it could level it self. One of motors did not start immediately after I gave throttle, so it turned upside down and it tried to turn back up, ground was just a bit too close to make full turn ;)
Damage:
- Broken motorshaft (cut half inside motor)
- 4 x M3x20 mm nylon screws broken (around arms)
- 3 x M3x6mm nylon screws broken (holding carrier boards)
- 2 x Propellers broken
Anyways, it does level it self really nicely if there is enough space to do maneuvers. We might need to consider more if there is a need for special failsafe start, eg to check what is our orientation when starting motors and also what way we should do correction movements. DCM already does this but we might need one extra step to it.
So if you have more than 5 meters space, it levels always well. It can level even from 3 meters but my success rate was 10 - 1 :)
Well all brushless motors have 3 cables due they are 3-phase motors. Full KIT will include smaller motors due most of people will be happy with them. With those motors you can easily have camera like GoPro HD, Sony Bloggie or similar and still have around 10 mins of airtime with 2600mAh battery.
@Taylor, for US people easiest way is just to make 2 orders, one from DIY and then just APM from SFE. Domestic postal payments are anyways rather small in US what I know. For outside US it's different because users still need to make two orders if buying from US and that makes overall prices a lot higher due double international payments, taxes etc.
PhiFUN can also ship to US but I don't see so much point on it due postal payments will be higher than getting it locally. Ok if all local shops are out of stock and PhiFUN still have or there is something in order that cannot be found from locas and no time to wait untill local stock levels are back up, well why not :)
Even tho I guess that more advanced people will like to have some guidance on how to figure out the parameters themselves if they build their own frame or use other motors.
One question on the test results: what is the 3rd line for? Is it the weight that the 4 motors will be able to lift?
And which motors will be part of the KIT? The small or the big one?
Thx
Simone
Here is test results of motors that we choose to use. All there motors are made especially for us in factory and we have full support for them which means also spareparts like shafts etc.
I allready have the APM and oilpan. Put it together and programmed it. All sensors work fine.
TX on the way.
Now waiting for the frame to come out.
Even many european shops are restricted by these similar law if they export goods. Because PhiFUN is physically located in a country that has never been in war with let's say western countries, we do not have any restrictions on electronics/software exports. so PhiFUN is only place that can officially sell and export all products in one box and even include software if needed.
Many simple things are not actually so simple as they might look. :)
9
10
11
12
13
of 82 Next
