I have been looking into my own method of mounting the APM with antivibration in mind.
To this end I wanted to source some freely available components specifically designed to reduce vibration.
I found a couple of such products which I am hoping will be ideal.
These coupled with a custom mounting plate, I am hopeful it will be a good solution.
First the mounting plate which will be cut from 1.5mm carbon fibre.
In each corner of the above plate will be an antivibration softgel bush which allow the plate to "float" on the main construction plate.
The APM case is then fixed to the mounting plate using SoftGel 15mm x 15mm x 5mm cube pads.
I'd be interested in any views people may have.
I have the parts here ready, but thought i would throw my prosal to the masses before the CF plate is cut.
Steve
i had been playing with silicon earplugs with 10mmx6mm and 3mm internal hole.
These are great and should work really well, I have posted links to them on the new Arducopter Wiki anti vibration page.
The bushes are the S5 - http://www.gelmec.co.uk/GelmecSoftSiliconeGelGrommets.html
The SoftGel cubes are http://www.gelmec.co.uk/GelmecSoftSiliconeGelTape&Chips.html and supplied on a sheet of 25.
I'll let you know how I get on and post some pictures.
where did you finde those rubbers ( the first right photo)?
I love the recent enthusiasm in anti-vibration considering that vibration can make your camera/photo quality horrible and can mess with your autopilot!
Keep up the good work!,
Josh
