APM 2.012 + REMZIBI OSD
With the APM together, it can display much information on the screen, e.g. the attitude of the plane, GPS data, NAV data, etc. The details of displayed information can be found in the web site of Remzibi OSD and the ARDUmV1_71.txt. Blake Krone has done great works to integrate the OSD and the APM. However, due to the fast development of the APM, some source codes are out of date, and thus a few modifications are needed to make them work properly. In this article, we give a detailed instruction of those modifications.
Our work is based on
1. APM 2.12 source code. Arduino-0022 IDE.
2. The firmware of OSD is ARDUmV1_71.hex
3. The serial port of the OSD is connected to serial port 3 of the APM (i.e. Telemetry port). Because the OSD does not send data to APM, the TX pin of the OSD is not required to be connected. You can also connect the Xbee to the serial port 3 of the APM in the meantime. In such case, the RX pins of the Xbee and the OSD are connected in parallel, and You MUST NOT connect the TX pin of the OSD. The Baud rate of the OSD is self-adaptive, and it is usually below 115200.
Here are the modifications:
First, download OSD_Remzibi.pde, and then modify some parameters according to the definitions in the code of APM:
1. In function print_osd_data(void)
Original:                    SendSer(GPS.date,DEC); //Date
Modified:       SendSer(g_gps->date,DEC); //Date
Comment:     This parameter is the GPS UTC date
Orignal:             SendSer(GPS.time,DEC); //Time
Modified:       SendSer(g_gps->time,DEC); //Time
Comment:     This parameter is the GPS UTC time
2. In function void print_osd_ahrs(void):
Original:         SendSer((pitch_sensor/100) * -1,DEC); //Pitch
Modified:       SendSer(dcm.pitch_sensor/100,DEC); //Pitch
Comment:   This parameter is the pitch of the plane.
Original:         SendSer(roll_sensor/100,DEC); //Roll
Modified:       SendSer(dcm.roll_sensor/100,DEC); //Roll
Comment:     This parameter is the roll of the plane.
Second, modify the source of APM (ver 2.12):
① In APM_Config.h :
Add following codes:
#define OSD_PROTOCOL OSD_PROTOCOL_REMZIBI
#define OSD_PORT 3
#define OSD_MODE_CHANNEL 7
These macros tell the APM to use the serial port 3 to connect to the OSD under the REMZIBI protocol. The channel 7 is used to control whether the OSD displays. You can change the serial port or control channel if it is needed.
② ArduPilotMega.pde :
In function medium_loop(), add following codes before the break statement in case 3:
#if OSD_PROTOCOL != OSD_PROTOCOL_NONE
print_osd_ahrs();
#endif
In function slow_loop (), add following code before the break statement in case 1:
print_osd_data();
#endif
// Read OSD Mode Switch
#if OSD_PROTOCOL == OSD_PROTOCOL_REMZIBI
read_osd_switch();
#endif
③ defines.h :
Add following codes after “//GPS type codes”:
// OSD type codes
#define OSD_PROTOCOL_NONE -1
#define OSD_PROTOCOL_REMZIBI 0
④ commands.pde :
In line 251, add following code at the end of function init_home():
// Save Home to OSD
osd_init_home();
#endif
Now, all the modifications have been done. Copy the OSD_Remzibi.pde to the folder of the source code of the APM 2.12(APM Trunk\ArduPilotMega), start Arduino, build the sketch and upload to the APM.
3689404993?profile=original
 3689404945?profile=original
Uploads are not downloaded,Why?ArduPilotMega2.12+remzibi_osd.rar
OSD_RemzibiV2.pde
chineseV.pdf
Thank LEE,hazy,Blake Krone's
  • Many thanks Matthias, i should remove all those and honestly i did not pay attention regarding the /* */
  • me being stupid .. : Did you keep the /* */ that comments and therefore removes all those lines at compilation ?
  • Yes , i did and find hereafter the complete data :
    #define OSD_PORT 3
    #define HIL_PROTOCOL HIL_PROTOCOL_MAVLINK
    #define HIL_MODE HIL_MODE_ATTITUDE
    #define HIL_PORT 0
    #define GCS_PROTOCOL GCS_PROTOCOL_MAVLINK
    #define GCS_PORT 3
  • Dider, did you declare as per the original post:
    ① In APM_Config.h :
    #define OSD_PORT 3
  • It is getting better butr unfortunately i still have the following error:
    ArduPilotMega.cpp: In function 'byte readOSDSwitch()':
    OSD_Remzibi:57: error: 'OSD_MODE_CHANNEL' was not declared in this scope
  • Hey that's the point : APM send GPS and attitude information to the OSD via the GPS port.
    You would need a special version of Remzibi firmware as explained by Blake's original post :
    http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A252631
  • Very interesting.
    Does the Remzibi takes the GPS input from the Ardupilot or does it still needs it's own GPS ?
  • Yes, using the new
    OSD_RemzibiV2.pde
  • Many Thanks Matthias
  • That's normal , you should use the new pde file https://storage.ning.com/topology/rest/1.0/file/get/3689404877?prof...
