I spend a gorgeous morning at the field with Jason Short testing code and tuning PIDs. He was focusing on ArduCopter 2.0.40 and I was just dialing in the PIDs for the HobbyKing Bixler, which is our current recommended platform for beginners.
I think I've got them pretty close, so I've posted the config file in the manual here with the rest of the config files for standard aircraft. Just load it in the Mission Planner and write it to APM, and you're ready to go.
Here's the RTL circle:
This is a 2011 post you are reopening, things have moved on.
If I go directly to the Wiki I see this
If I click on "Intructions" I get
..nothing to select under "Tuning" which is different if I use the link from your post.
KuntL: What do you mean? That link takes you to the top page of the manual. You then use the menu in the left column. This config files are in Flying/Tuning.
Something is messed up with the APM Manual Website.
If I go to the manual and the config file via your link above, I can get it.
If I try to go there via the standard link "ArduPilot>ArduPilot Mega Manual" on the top of the page, I dont get the link for the Config File.
um dah :) sorry i never saw that thanks :)
Allan: I posted on it here. There's loads of room--more than the EasyStar. It's an excellent UAV/FPV platform.
i like this plane but Chris is there enough room to fit everything in the fuse and is it possible to take some photos of the setup please
I have built one plane in XPlanes, but I was actually modifying an Extra to match the Extra MX from Precision Aerobatics. Bixler was my next planned plane purchase anyway, so I guess I should go ahead and buy one an contact those guys to try and get a model to start with.
Now all we need is a X-Plane model of the Bixler (and/or the other airframes posted,) to test with...
Now that would be a sweet combo for the wiki site, Anyone here know how to create xplane aircraft?
No, totally stock. Standard ARF kit.
BTW, waypoint following is a still a little sloppy, so I've got some tuning to do there, but it's good enough to get started with.
1
2
of 2 Next
