We're getting ready to launch the beta ArduCopter 2.0 (formerly known as ArduCopterMega, or ACM), and much has changed. First, it's our first real quadcopter UAV code, designed from the ground up for fully scripted autonomous missions as Jason's runs at Sparkfun demonstrated. It's also totally built on the APM code base, so sophisticated MAVLink mission planning and telemetry is built in and it inherits APM's mature navigation algorithms.
Replacing the LabVIEW configurator that we used in ArduCopter 1.x is a configuration utility built into Michael Oborne's fantastic APM Mission Planner. This both gives you command-line (CLI) access to the ArduCopter 2's interactive setup process, as well as a graphical display of all the sensors at work, so you can see at a glance that everything is working right. And because it's all MAVLink-based, you can use it equally well on the bench via USB as at the field (or in the air) via Xbee. And it will work for any MAVLink-based UAV!
Unlike the old Configurator, you don't need to install LabVIEW to use this. Although the Mission Planner is Windows-only right now, you can use ArduCopter 2's built-in CLI to set up the board and software on any operating system, which will give you a text-based version of all the same data. Our aim is to be totally cross platform, just like Arduino.
As with APM, the Mission Planner will also load the code, so there's no need for Arduino anymore (unless you want to tinker!). Our aim is to make ArduCopter the easiest quadcopter UAV setup on the market. We've still got a ways to go on that, but the progress so far has been very impressive. There are a lot of RC quads out there, which are increasingly easy to set up, but very few real UAV quads with autonomous mission planning. We'd like to make setting up a UAV no harder than setting up a RC aircraft. ArduCopter 2 is a big step in that direction.
As for the release of ArduCopter 2, we're very close. The dev team will review the last outstanding issues on Sunday, with the target of releasing the first beta next week, with documentation.
I love the Mission Planner, it makes everything so simple for setups now. Another step I'd really welcome would be the ability to opt between auto update of the latest code from the internet, and also the option of a local folder to search for the latest code you may have downloaded. That way you can use Arduino to edit the code, and then point MP to upload it after. Doing all the hacks, compiling, and uploading is beyond my pea-brain I'm afraid. I'm trying to set voltage division ratio for the Current sensor, enable camera-stab and other goodies that aren't yet built-in to the optional hardware page on the setup in mission planner. I'm NOT complaining, it's just feedback from a grateful noob! ;)
just got back from using the copter in a competition, didnt do so well, but survived a water landing and managed to live!
im updating to copter 2 code, xbee seems to be behaving oddly..
summer will be fun :D .
if i can get my gps to lock ...
1) it assumes forward flight
2) it does not discern between gravitational acceleration and "translational" acceleration
3) it doesn't really deal with translational drift (caused by wind, for example)
None of that is critical, of course.
Congrats!
Question, tho.
Will the DCM algorithm used in AC 2.0 still be the one geared towards planes (like it has been so far) or has it been revamped with 'copters in mind?
Looks great, many thanks to the development team.
For Mac users - it seems to run under mono, just been playing with the planner in OS X 10.6 which works well (there's even a handy installer in the download)
Paul
1
2
3
of 3 Next
