Finally, you can now use ArduPilot Mega without ever having to touch Arduino! Michael Oborne's terrific Mission Planner will now check for the latest code online and load the firmware directly, with no Arduino compilation process required. I've updated the APM 2.0 beta instructions to show how to use it.
You can still use Arduino if you want to fiddle with the code, but most people won't need it at all. No need to even have it running on your machine!
Right now it only supports the default configuration, but in the next day or two it will allow you to choose other common configurations, such as Xplane simulation mode.
Frank: magneto orientation is currently defined in the APM_Config.h file if you're using non-standard configuration, as you are. We won't support that in the firmware autoloader, but it might be something we could add to the CLI.
Thank you Chris. Will there also be a possibility to define the orientation of the magneto, I am using the Spakfun.
Looking forward to the final 2.0 the Beta is already great!
//Frank
If I use the APM Planner to upload the the firmware to which loacation I need to point the APM Source Location under the Option Tab? (there are no 'arduino' files any more)
Darren, the same off into the distance and back thing happens with my system when I'm doing Xplane HIL too. Trying Flightgear was on my list of things to try.
It seems to be a fixed offset on each mission, but the offset is typically different session to session.
The other thing was that I was going to look at the HK logs in the recordings I made, but I can't actually find the files despite being able to play them back. The jumps are in the playbacks as well.
I'd also seen the -ve altitudes, but not in the last few days prior to the beta release.
well, looks like flight gear will take all night to download... must have slooooow internet tonight
so will have to check that out tomorrow...
