The new ArduPilotMega Shield "Hotel' Version 1.0 has finally replaced our old and problematic Foxtrap 2.2, many of the changes are just to accelerate the assembly process and reduce production failure rates, working in conjunction with the very supportive Invensense Team (Thanks guys!).
Note: if you are a user with the current boards, they're fine. The problems were in the production process, which required us to go through extra steps to ensure they passed QA. The new board is more for our sake than yours!
Manufacture changes:
-Improved gyro pads.
-The boards now came with Lead-Free Silver Immersion for an even surface (Turns goldy when baked).
-Added one 0603 resistor pad on voltage divider for automatic machine placement. I should have added it to all the resistors. =/
User Experience:
-Now that is easy to assemble, boards availability will be improved.
-Solder jumpers to optionally enable/disable gyro low pass filters.
-Added labels that suggest where the female headers should be placed.
Bugs fixed:
-Reset button now works under any condition.
-Analog supply for the pressure sensor is now attached to the analog 3.3 voltage regulator.
By the time I wrote this post I still had some Oilpan in stock, please hurry because we are moving to a new warehouse and we may be out for around one week again, just in time to start production with our new Japanese made Manncorp 7722V. Many thanks to the Mancorp team that is also located next to us in San Diego,CA!
Eagle Files:
Also many thanks to Star Wars (TM)!
http://diydrones.com/profiles/blogs/update-on-product-availability
I use the data flash chips in a product and you couldn't find them anywhere for a few weeks a while back.
We are still looking and testing behavior of these filters due there are a lot of conflict on our field tests that we try to find. On older IMU filters can be disables by removing those 3 small capasitors. But as I have flown with and without them... I have not seen any difference.
So old Foxtrap board is as good as this Hotel board.
Do I need to get new board to fly arducopter, will it perform better ?
And how do I change tis filters on the old board ?
