3689604406?profile=original
NOTE: Parameter settings was also broken. Next release we will also have 'beta' releases so we can avoid these simple mistakes getting into stable releases, and if you are so inclined, can help us test before release.
2.0.13 improves connectivity with bluetooth devices as well. :-) Thx for all the reports so far on these issues. You can always try the daily builds if you like to experiment see http://firmware.diydrones.com/Tools/APMPlanner/daily/
NOTE: auto tlogging was broken, so we have pushed a minor update to fix the issue. There are some other small changes as well, see the release notes for more info
Happy Independence Day for those in the US.
A new release of APM Planner 2.0.13 is available.
In this release we have
  • Upload to Droneshare
    • You can now upload logs to Droneshare from the Graph View.
  • Support for APM Mission Planning commands
    • All APM specific commands are supported. (excludes ROI, but you can add with Mission Other command)
  • Mission Elevation Display.
    • You can now see the elevation profile and compare against the terrain based on the Google map data
  • Rework of serial port handling.
    • New improvements in stability of serial port handling including bluetooth support.
  • Update improvements
  • Mission Editing performance issues (deleting 119 waypoints down from 10mins to 17secs)
  • Graph View now show mode changes with text for bin/tlog/log file formats.
  • Support for Ubuntu 14.04LTS (Trusty Tahir) builds (coming Monday, see preview here (It's identical except the version reports as 2.0.10)  (Trusty Tahir builds are now ready see here)
and many many more fixes... download here http://ardupilot.com/downloads/?category=35
Enjoy
The AP2 Team
PS: Users will be notified automatically if you have installed a previous build of AP2.
    Locator? What it that ?
    When will the "Locator" be integrated?  I've seen it working and it sure looks nice and a very needed function!
  • OK cheers Aaron
  • Hi Stuart, for future use the common mavlink message reference is here: https://pixhawk.ethz.ch/mavlink/
  • I think I'm sorted now...I cheekily created a misison in mission planner and loaded it, then opened APM planner 2 and read it and found it is #201, I then googled this and found this
    https://github.com/GaloisInc/ardupilot-mega/blob/master/ArduCopter/...
    Cheers,
    Stu
    Fork: DO NOT SUBMIT PULL REQS/BUG REPORTS HERE. Contribute to GaloisInc/ardupilot-mega development by creating an account on GitHub.
  • I have searched with no luck, how do I use the other commands for ROI? I can't find the command # required for ROI.
    I am trying APM planner as it seems to work with my bluetooth bridge where Mission Planner doesn't.
    Thanks Aaron!
  • The dataflash log thing turned out to be a simple bug: https://github.com/diydrones/apm_planner/pull/390
  • Nice Job! particularly the graph section that helps newbies like me understand some of whats happening in the background.
    Sir Chris mentioned the queue... please consider the backup function
    Thanks Again
    RoboBill
    Bill, is there joystick control in APM:Planner?
