3689579503?profile=original
[UPDATED to 2.0.7: we had a serious issue with serial connectivity and APM2.x and FTDI, it now fixed. All users that download 2.06 will be notified automatically of the new release]
APM Planner 2.0.7 has been released. This is the first official stable release of AP2, which is the cross-platform (Mac/Windows/Linux) ground station/setup utility for APM/Pixhawk-based UAVs.  Here's a list of features
APM Planner 2.0.7 Release Notes
Here’ the first official release of APM Planner 2.0.
Features
General
  • Auto Update. new stable versions will be notified automatically.
    • will add a feature to also add daily builds to this.
Flight Data View
  • Real time monitoring of telemetry information (Quick View & more detailed Status View)
  • Real-time control of UAV
  • Message view tat shows PreArm warning messages
  • Primary Flight Display (HUD)
Flight Plan View
  • Waypoint editing
  • Saving and Loading waypoint files
  • Map Vendor selection
Initial/Config & Tuning Views
  • Full Configuration of APM:Plane and APM:Copter (APM:Rover is a work in progress)
  • Reworked Battery Monitor setup where you can select known presets
  • Parameter Download for known frame types
Graph View
  • Real-time plotting of MAV link telemetry values
  • Dataflash Log analysis
  • Value are plotted on a range that is scaled automatically
  • Values can be group on in same range (up to 4 groups)
  • Ranges can be set manually
Terminal View
  • Allows access to the APM CLI Interface
  • Used to download Dataflash logs (MAVLink downloading of logs coming soon)
  • Option to convert logs to KML format for Goole Earth view.
Known Issues:
  • Google Maps shows only outlines at some zoom factors
  • When switching between APM:Plane/APM:Copter/APM:Rover restart is required
  • Multiple MAV support is not fully tested and is a work in progress
more detailed issues can be found here http://github.com/diydrones/apm_planner/issues
For support please post here first APM Planner Support Forum
Going forward
  • Improve support for Google Maps
  • Improvement of Waypoint editing to support specific APM waypoint types
  • Automatic grid pattern generation
  • Incorrect warning on windows install about installing Win C++ 2008 redistributables (just ignore, click OK)
Enjoy: and please report any issue you have, the next stable update is scheduled in about 2 weeks. We want this to be continuous improvement on that schedule.
Thanks AP2 Team.
3689579400?profile=original
    @Luis: Thanks for the message of support. I updated the image to reveal the full country name ;)
    I added TCP support. You need to put AP2 in advanced mode. Add a Link and then reconfigure it to be a TCP link
    @Dave: Please raise the issue here APM Planner Support Forum and I'll take a look in the morning
  • I'm having a minor issue with this release. On a MacMini running 10.9 and RC3 I am able to connect to a new board with no problem. With my MacBook Air with 10.8 and 2.0.6 I can't get any data on the HUD after connecting.
    This error will show up eventually: Please check if the baud rates of APM Planner and your autopilot are the same.
    And if I wait a little longer this message will show up: Your MAVLink device seems to use the deprecated version 0.9, while APM Planner only supports version 1.0+. Please upgrade the MAVLink version of your autopilot. If your autopilot is using version 1.0, check if the baud rates of APM Planner and your autopilot are the same.
    I am going to dig a little deeper to make sure its nothing on my end. I've installed the FTDI drives twice now. Thanks for all your hard work.
  • Hi Bill...congratulation for the release and your work's..i living in Paraguay...small country in center of southamerica...appear in the picture...nice to see this picture..i use ardupilot for 4 year ago to today...practical of beginner of the project...and very happy for the evolution and progress of the ardupilot project...
    Thank you
    Best Regards
  • mac version finally, thanks very much developer team!
    @Adam: it's another option. that works on Linux and OSX. Its based on QGC, but the projects have different aims. We are supporting APM/Pixhawk as a primary platform. QGC is supporting more than one autopilot. If you are using only APM and Pixhawk using APM Planner will be a good fit.
    Fixed now.
    The download link is not working at the moment.  For the 8 people who have downloaded, you have rc5, not 2.0.6.  We are working to fix the problem.  Please stand by
    Congratulations Mike & Bill!!
