Arducopter 2.7 Auto-Flip
A while back Jose Julio built a simple state machine for doing copter flips. I integrated it into AC 2.x a long time ago but never flew it. Then, once I built the Flash simulator I could finally test it without doing too much damage or loosing my quad to a fly away.
The original code was quick and dirty which lead to a few issues, one of which was a tendency to turn the my quad into an air to ground missile. The new code which is in 2.7 added a few items:
  • an emergency exit from the state machine (roll or pitch hard to exit)
  • a rate controlled loop rather than a using momentum for the second half of the roll
The state machine takes control of the throttle, roll and pitch until the flip is complete. It breaks up the flip into 4 main steps
  1. Gain altitude - up the throttle for 1 second
  2. Roll hard until we go past 90°
  3. Maintain 400°/s roll until we are 90° from level
  4. Stabilize with a desired angle of 0° for a nice controlled return to level
3689471366?profile=original
The mode is enabled by setting the CH 7 option to Flip. Bringing CH 7 high while flying any mode will trigger the flip, but you must be armed and flying to get the flip code to trigger. You must return CH 7 low, then high again to reset the state machine and do another flip.
Jason
    CH7 going high will trigger the flip. It won't flip again until you toggle it. And it will finish the flip regardless of the switch position.
    It's only a 15% boost in throttle.
    It's pretty bullet proof if you are high enough. I've had a few instances were it were it didn't flip, but just started rising. A quick roll right and it exited the state machine.
    Jason
  • Jason - when you say that step one in the code is to up the throttle to gain altitude for one second, is that 100% throttle? Being that I have a hexa with 880 motors, neighbors may think I'm sending up an ICBM :)
  • This is really amazing work - and a wonderful video with the angles to boot! I might have to try this with a hexa...
  • I was just wondering if this is by any chance the most awesome thing I have ever seen? Just wondering what the failure to success ratio is using this feature? I really want to try this, but I don't want to trash my quad.
  • Do you have to keep Ch7 high until the end of the maneuver? Will low-high trigger the next flip on the high immediately or will the high only trigger the reset and another low-high is required for the next flip?
    That is fantastic!  Love the video with the 3 different angles!
