Arducopter 2.0 Beta first release!
3689405696?profile=originalMark Grennan
We're finally comfortable enough with Arducopter 2.0 to release it as a beta!
AC2 is a complete system for a range of Multi-Copters. It started out as a side project for me and turned into an obsession. Oh Well! Copters turned out to be even more addicting than I ever thought.
AC2 doesn't bring over any code from NG, but I tried to make the transition fairly easy. It should fly virtually the same and the default PID values are equivalent.
I think it's pretty close and fairly bug free, but I know there are a few left and that's why we need the community to help us find them and submit patches that improve performance. If you have an issue or something to contribute, please use the Google Code Issues list for prompt responses. I won't be tracking bug related comments in this thread. If you can, please include a log file from you flight with an indication how many seconds in you had a problem.
Google Code issues list
And one last note before we talk features: Safety first! Don't load this and expect it to work exactly like NG or that it will work out of the box with no issues. Don't calibrate your ESCs with the props on. Don't turn off your radio while it is armed. Test in your hand before adding props. Test in your hand after adding props. Always be prepared to put it back into stabilize in case an Auto mission behaves unpredictably. etc... Simple stuff, but you are in control and take the responsibility of flying when you load this code.
Now that's out of the way: Download here [UPDATE: The Mission Planner now supports direct AC2 firmware uploading, so please use it to get the code instead. No need for Arduino or compile source code anymore! That said, if you want to fiddle with the code, you can always get it here and use Arduino as usual.]
The full ArduCopter 2 Manual is here. Please read it before using the code!
What's New:
Simple mode allows the user to save the orientation of the copter while arming the motors. This means the copter can yaw in any direction and the sticks will reference the original orientation. Great for learning or  - emergencies in the air.
Position Hold is now called Loiter to be compliant with Mavlink Ground control stations.
RTL will fly the copter home and hold the position
Auto will fly a mission stored in EEPROM.
Copters supported:
+, x, tri, hexa+, hexax, y6
AutoPilot commands supported:
MAV_CMD_NAV_TAKEOFF   - Copter will takeoff and rise to a defined altitude.
MAV_CMD_NAV_WAYPOINT - Copter will navigate towards a waypoint. (Beta 1 disabled options: altitude minimum, time delay)
MAV_CMD_NAV_LAND - Copter will immediately go into Loiter (position_hold) and begin a controlled decent.  Mission scripting ends after this command.
MAV_CMD_NAV_LOITER_UNLIM - Copter will Loiter at current location.  Mission scripting ends after this command.
MAV_CMD_NAV_LOITER_TIME - Copter will Loiter for N seconds. (disabled for this version)
MAV_CMD_NAV_RETURN_TO_LAUNCH - Copter will return to Launch (home position)
MAV_CMD_CONDITION_DELAY - will delay the execution of next conditional command
MAV_CMD_CONDITION_DISTANCE - will delay the execution of next conditional command until the copter is within a minimum distance to next waypoint
MAV_CMD_CONDITION_CHANGE_ALT - will send copter to desired altitude, overrides next waypoint altitude.
MAV_CMD_CONDITION_YAW - controls how the copter will yaw. Angle (relative or absolute), speed, and direction are inputs.
MAV_CMD_DO_JUMP - sets the next waypoint to the desired index - for conditional loops
MAV_CMD_DO_SET_HOME - changes the home location
MAV_CMD_DO_SET_SERVO - outputs servo channel number to desired PWM
MAV_CMD_DO_SET_RELAY - sets the relay to postion 1 or 2
MAV_CMD_DO_REPEAT_SERVO  - toggles servos
MAV_CMD_DO_REPEAT_RELAY - toggles the relay
In flight tuning:
You can tune aspects of flight with your channel 6 flaps knob. To enable this, you need to compile and update AC2 directly with Arduino.
See AP_Config for options.
How to setup your radio:
ch1 = roll
ch2 = pitch
ch3 = throttle
ch4 = yaw
ch5 = mode switch - use your 3 position switch
ch6 = used for in-air tuning - not currently active, see AP_config.h for options
ch7 = use to set throttle hold value while hovering (quick toggle) - default position should be a low PWM value!
ch8 = NOT used!!! - this is the hardware manual - it's dangerous to use for quads BEWARE!!!
How to use the CLI:
You must go through each item and set the values to match your hardware
"setup" menu:
erase - when installing AC2 for the first time, run this to erases bad values from EEPROMS – just in case
reset - Performs factory reset and initialization of EEPROM values
radio - records the limits of ALL radio channels - very important!!!
pid - restores default PID values - only needed if you have changed them in flight with CGS, not for setup.
frame - sets your frame config: [x, +, tri, hexax, hexa+, y6]
motors - interactive setup of your motors, (X, +, or tri supported) Point your stick towards the motor to make it spin, throttle is passthough.
level - sets initial value of accelerometers - hold copter level, don't move it.
modes - sets the flight modes assigned to each switch position (you have 6 available), toggle roll to change, enter to save.
current - enables an Attopilot current sensor: [on, off, milliamp hours]
compass - enables the compass [on, off]
declination - sets your local declination value – lookup online for accuracy [decimal degrees!]
sonar - Sonar hooks to the "pitot" port which is an analog input [on, off]
show - a formatted output of all the settings
"test" menu:
pwm - outputs the pwm values of all 8 radio channels
radio - outputs the control values of all 8 radio channels in degrees * 100 or other value (see radio.pde)
gps - outputs GPS data
rawgps - outputs raw, unparsed GPS data
adc - outputs raw adc values
imu - outputs euler angles
battery - outputs voltage readings to analog in 0-3
current - outputs voltage and current from an AttoPilot current sensor
relay - toggles the relay
sonar - outputs sonar data in cm
waypoints - dumps stored waypoint commands
airpressure - raw output of absolute presure sensor
compass - outputs compass angles in degrees (0 = north)
xbee - outputs an XBEE sequence used for range testing
mission - writes a default mission to EEPROM [null, 'wp']
- choosing 'wp' option will send the copter 15 meters North and back again.
eedump - raw output of bytes in eeprom
"logs" Menu:
See the APM wiki to better understand how to dump logs and how to set the types of data you want to record.
AC2 Flight modes:
All of the modes allow the user to control the copter with the normal controls. You can get yourself out of a jam sometimes by simply nudging the copter while in AUTO or LOITER modes.
Options include:
ACRO - rate control only. not for beginners
STABILIZE - copter will hold -45 to 45° angle, throttle is manual.
SIMPLE - Remembers the orientation of the copter when arming, allowing the user to fly more intuitivey. Manual Throttle.
ALT_HOLD - Altitude is controlled by the throttle lever. Middle is hold, high = rise, low = fall.
LOITER  - When selected, it will hold the current altitude, position and yaw. Yaw is user controllable. roll and pitch can be overridden temporarily with the radio. Altitude is controlled by the throttle lever. Middle is hold, high = rise, low = fall.
RTL  - Will try and fly back to home at the current altitude.
AUTO  - Will fly the mission loaded by the Waypoint writer
GCS_AUTO - Not implemented
Special notes:
The props will NOT spin in stabilize when throttle is in the off position, even when armed.
Arming is Yaw right for 1 sec, disarm is yaw left for 1 sec. Just give it some juice to confirm arming.
Auto modes will NOT engage until the throttle is above neutral. So if you put the control switch to positio hold while it's on the ground, it will no spin up. Or at leat it shouldn't ;)
Good luck,
Jason
    @Paul & Others, your request has been fulfilled.
    Basic setup video for ArduCopter 2 (ArduCopter Mega) software
    In this video we will go trough basic setup of your ArduCopter. We are using totally "virgin" Assembled ArduCopter kit to make this video and it shows all things from level up calibration to calibrating your ESC's.
    Because of youtubes 10min limitation, second part will show how to enable magnetometer and sonar.
    This is earlier ArduCopter Mega software so some of the texts has changed a bit but general functionality is the same. In future those texts will change too and along the time we will make more informational videos for all our users.
  • I've got mine up and running on the new firmware. Thought I would put forward some lessons learned in the process.
    1) Start with the radio. I found that my configuration from NG wasn't the same as for ACM. So go back and verify that.
    2) Next load the code. I skipped this step due to the way the wiki menu is setup. I went to configuration without loading. This doesn't work. (Duh) I guess I just overlooked this and clicked the configuration button which says "First Setup" thinking that was the button to load the code.
    3) The first firmware load didn't work completely, it reported done but wouldn't actually arm the motors. Did it again and it worked fine.
    4) I started a new profile in my radio so that I still have the old in case I go back.  Negative side to this is I don't have all my rates set up as before. ACM seems much more touchy. I'm going to have to play with PID and rates to calm it down.
    Next... Try to run a mission.
  • Thanks very much Jason and the DIYdrones/ arducoter community. very much appreciated!
    Al
  • Nice job guys i love how easy it is two load code and then do the set up thanks  Tom
    @Emile,
    You can use other magneto orientations on APM_Config.h too. Just like we are using on jDrones Assembled ArduCopter kits. We have them installed on top of upper carrier board in front area of it.
    Two main orientations what we are using are comp up/pins forward and as default comps down/pins forward
    #define MAG_ORIENTATION       AP_COMPASS_COMPONENTS_UP_PINS_FORWARD      // Assembled kits
    #define MAG_ORIENTATION       AP_COMPASS_COMPONENTS_DOWN_PINS_FORWARD   // Maggy soldered to IMU
    If you need something else, it can be done too but like Chris said. We are trying to get it as easy as possible to configure and only offering one/two combinations. This way it will be easier for us to give support to users too.
    ArduCopter Quad v1.1 Assembled & Tested Quad
    R/C UAV and ArduCopter manufacturer and one stop shop. We make your FPV come true.
    @Chris: Looks like you're right. I'll add that to the default code and include it in today's update.
    @Mees: The Mission Planner firmware upload is for standard hardware configurations. We've worked hard to move as much configuration as possible out of the code/compile process and into the CLI or MAVLink settings that can be changed on the fly (or in the air), so most people won't have to use Arduino.
    But for those who have very unusual configurations that require changing the code itself, they will still need Arduino to do the compiling. At that point it's easy enough to also let it do the uploading, no?
    Emile: I'll let Jason answer the question about non-standard mag orientation. (I suspect you've got to change it in the config file)
    But mag offsets are now set automatically.
    @Paul: Did you read the manual? We rewrote it just for this release. Any suggestions on how to improve it would be very welcome.
  • @Paul:
    I have just read the Wiki from front to end, and i must say, i think it is rather logic, although i have only fired up my APM once. Just take your time to read it from beginning to end!
