ArduCopter (TBS Discovery Style)
3689498201?profile=original
Team-blacksheep have very nice frame for DJI-NAZA with some fancy PDB, but I don't have NAZA and I wanted some modification to mount APM2/2.5, so here is my version of that frame, no fancy PDB and PCBs, just black fiberglass :)
If you do have DJI NAZA go get that frame right NOW !
3689498526?profile=original APM2.0 with 90° pins fits under the top plate with analog and telemetry pins exposed.
3689498500?profile=original3689498413?profile=original
APM2.5 with ublox GPS.
3689498568?profile=original
3689498428?profile=original
Set the LED_MODE parameter to 9, It will slow blink when disarmed, solid armed, fast blink + beep on low battery.
3689498602?profile=original
The CG and the APM location moved a little bit, but it can fly as regular X quad. (don't pull back too much)
I just changed the AP_MotorsQuad.cpp X frame set-up to:
add_motor(AP_MOTORS_MOT_1, 55, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_2, 1);
add_motor(AP_MOTORS_MOT_2, -125, AP_MOTORS_MATRIX_MOTOR_CCW, AP_MOTORS_MOT_1, 3);
add_motor(AP_MOTORS_MOT_3, -55, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_4, 4);
add_motor(AP_MOTORS_MOT_4, 125, AP_MOTORS_MATRIX_MOTOR_CW, AP_MOTORS_MOT_3, 2);
Setup
Motors: Tiger MS2212-13 980KV
ESC: jDrones 18A (Flashed with SimonK FW)
I really like the 10X5 Graupner e-props (or new Carbon 10X5 e-props) with 4S 3000mah lipo, after some fine-tuning its very sharp fly.
Here some raw clips from Arducopter 2.8.1 tuning flights:
BTW Jani from jDrones (that where I CNC all my custom frames ;) ) has put together fancy RTF kit, so check that one out.
EDIT:
The top outside hols for the arms are ~0.5mm off, I think so chek it before cuting.
ARDU_DIS_APM25.DXF
  • Anyone with spare arms able to check if the holes are correct on the original dxf?
    @Yves, you got a message/friend request
  • This can be considered.
  • I´m not shure if the holes are 0.5mm off - great if someone have the time to check it.
    + in my Version of the dxf file I have altered the holes for the Controller so I can use my quanton Controller. If someone plan to use APM 2.5 the dxf file must be modified (copy the APM holes from the original dxf file)
  • Yves, are you willing to cut a glassfiber frame for me? I'm looking for the centerplates that Oyvind made with the holes for an APM (original dxf). We are neighbours ;-) (Holland)
  • Is this still true with the current dxf?
    EDIT:
  • I have a machine at home, but a home made for the hobby. (teamcnc.be) For carbon, we must be careful to dust.
    Are you satisfied with the 1.5 mm? Carbon or epoxy?
  • I´m using 1,5mm on mine.
    Here is the latest mod where I´m going to test using 190mm tubes in front and 260mm rear + changed the angle on the rear tubes.
    3692703600?profile=original
    The test props are 10"
  • And do you guys know a place to CNC it? jdrones does not respond, but maybe its still labour day.
  • As soon as I finished I will share it, of course.
  • I built with 2mm
