Hi all,
I have done an experiment today ,very simple but enough for my lack of programming skills.Thanks Armiche.
I was unable to make a wireless connection between arduimu and his test software ,it works perfectly with the ftdi adapter.
There is something in the code that ask the IMU via ftdi if its connected or something because the x-ctu terminal shows the messages being received,but the test software does not run.
"The solution"
I tried with the razor IMU with Jose´s Python software and it works!!! (with mod#2). To use the arduimu I did #1.
Mod #1 Change the output.pde ,the one in the razor folder goes to the arduimu´s one. Try to compile and then comment the line that shows a problem ,something about "performance report" .I will post it ,this is another computer. Upload to arduimu.
Mod#2 edit the Python app. with the COM port you are using with the Xbee and his baud rate ,I set both at 38400 bauds.
Of course the "airboirne" xbee needs a 5 to 3,3 regulator ,be carefull.
Hope you found it usefull for experiments.
Next we are going to connect arduimu to paparazzi via spi ......
Juan Martin
  • Ya, I was starting to doubt my sanity!  :-)  Should have done more research on Sparkfuns website. They have added a note on the shield board page now about this issue.
  • Finally !!!
  • OK, found problem was the diode in the DIN line. Bypassed with 120K 1/8watt resistor and data was perfect. Sparkfun has some info on this but not on page where xbee shield is.
  • Have you tried a wired connection first ? That way it´s easier to try different baud rates. Mismatching baud rates are number one failure .
    What arduino soft are you using?
  • Ok, many weeks later, I split the power supply and made sure both xbees and the IMU and computer were set to 57600 baud. The two xbees are talking but the data is not usable. almost all showing as 00 in the hex window. Can't figure out where I am going wrong. If I power down the IMU the data flow stops so i know the xbees are talking.
  • Please let me know ,I run from a battery and the xbee from a custom regulator LM2937ET.
  • Yep, and I did that. It works fine. I think the problem may be that I was trying to run both the IMU and the xbee off of the regulator on the IMU board. I noticed it was running warm so I am in the process of splitting the power source. Perhaps the load was to much and the logic level was not consistent?!? I'll let you know how the split power supply works out.
  • It seems that the connection is ok ,Can you try first a wired connection using the Python app.???
  • Can anyone tell me how to connect the 9d0f IMU running the SF9DOF_AHRS software directly too an XBEE. I have tried using the xbee shield using the following connections:
    IMU XBEE
    DTR ---------> DTR
    TX0 ---------> DIN
    RX1 ---------> DOUT
    3.3V ---------> 3.3V
    CTS ---------> CTS
    GND---------> GND
    The other XBEE is connected to the computer using the SF USB XBEE shield.
    I am getting a connection, but no data. Thank You for your input.
    Kraig
    Canton, OH USA
  • A ke si!!!! Pampero forever.
