Here are some brief details:
KDA20-22L motors, Turnigy 30A ESC's converted to I2C, APC 10 x 4.7 props, UBEC, GWS RX8 receiver, 10mm sq aluminium frame with pcb central hub and mounting plates
RC1 code modified to add I2C motor control and mixertable for controlling 8motors. ArduOktoKopter.zip
Peter
I have discovered that my Xbee used with the Configurator will not work if the I2C bus to the ESC's is connected. Any suggestions as to why this might be?
Peter
Peter
I commented this out as I was not expecting to read any data back from the ESC. Why might the bus freeze without a read?
Peter
http://code.google.com/p/lnmultipilot10/source/browse/branches/Redf...
I see that in your code you comment :
while(1)
//while((Wire.available())&&(i<6))
buff_i2c[i] = Wire.receive(); // receive one byte
i++;
if (i>6)break;
//Serial.print(i);
if (Wire.available()==0)break;
But you need this part because without it you can have same problem on bus .. freeze the code fox example ...
Regards
Roberto
The WireMotorWrite is used in the Motors code as the method to write the data to the ESC. I am not sure where you think I have something missing?
Thnak you for your help and interest.
Peter
I check your code that is my mixertable ... Congratulation you are the first user that are using my code in your Multicopter :) So i check it and i see that you change the void WireMotorWrite() function .. without that code that you comment you can have some freeze on i2c bus ... is better that you use it.
Do you have a VIdeo of your first flight ?
This is my first video using the mixertable and Hexafox Coaxial configuration :
http://www.virtualrobotix.com/video/multipilot-board-hexafox-coax-1
If you look in the zip file above you will find the 'copter code including the mixertable. I used the data suggested by Arthur P on the Aeroquad forum but had to change the sign of the yaw values. I number my motors as suggested by Arthur (1 at the front going clockwise).
Peter
Regards
Roberto
1
2
3
of 3 Next
