ArduOktoKopter Flies
3689377728?profile=original
I have just tried my Oktokopter on its second flight (despite the wind and light rain that made it a very short flight) and it seems flyable. When the weather calms down I will give it a longer flight and try and shoot some video.
Here are some brief details:
KDA20-22L motors, Turnigy 30A ESC's converted to I2C, APC 10 x 4.7 props, UBEC, GWS RX8 receiver, 10mm sq aluminium frame with pcb central hub and mounting plates
RC1 code modified to add I2C motor control and mixertable for controlling 8motors. ArduOktoKopter.zip
Peter
    Do you have an a video of your flight ? What kind of implementation are you doin to standard code ? Are you see my Mixertable ?
  • No have not tested payload - there is a great deal more testing to do.
    Peter
  • Hi.
    Great job! What is the max payload of your oktokopter? Did you test it?
    The mixertable for i2c and pwm regulator is available unitl first revision of code .. I yet fly Hexa radial , Hexa Coaxial and Oktokopter ..jani are working to integrate it in the next Arducopter NG revision.
    Regards
    Roberto
  • I have added a file that includes my modified code, code for the ESC's, instructions on modding the ESC's to I2C and my assembly file. Enjoy!!
    Converting the code to a hex would be very simple and would require the mixertable to be adjusted and some references to motors 6 and 7 to be removed. If you want the mixertable for a hex then let me know - the yaw values need to be the correct sign compared with some of the published tables I came across.
    Peter
  • I think you should get in contact with the arducopter team, your help would be greatly appreciated.
    Great stuff there, i am anxiously waiting for the Hexa-Code to be published...
    Regards
    Daniel
