- All the ArduPilot 1.0 functions: programmable 3D waypoints; return-to-launch mode, in-flight reset ability, fully programmable actions at waypoint and totally expandable board.
- Now integrates the stabilization and navigation functions, eliminating the need for a FMA Co-Pilot and vastly improving waypoint tracking
- Controls elevator and ailerons/rudder. Throttle control coming in 2.1
- "Fly-by-wire" mode stabilizes the aircraft in RC mode, duplicating the function of the FMA Co-Pilot
- Stores home waypoints and sensor calibration in EEPROM, so they are retained even in the case of a system restart
- Controls altitude with the elevator, vastly improving performance in wind
- Currently optimized for the three-channel EasyStar. Versions have also been tested on Funjet and four-channel Superstar (code coming soon)
- Simple in-field calibration process
- Can use any thermopile XY sensors (default settings are for the FMA sensor, but Paparazzi, AttoPilot and custom sensors can also be used)
- Currently supports the EM406 GPS. Support for Locosys and Ublox GPS modules coming soon
- Uses "chained PID loops" to combine the stabilization and navigation functions seamlessly
- ArduPilot board ($24.95)
- EM406 GPS module ($59.95)
- A FMA XY sensor ($42.95; if you already have a FMA Co-Pilot, you can use its sensor). If you're buying the FMA sensor by itself, you'll also need to purchase a cable.
- A FTDI cable, such as the Sparkfun ($13.95) or Adafruit ($20) ones
- ArduPilot 2.0 code (Free)
- Uses Z sensor for self-calibration in the field
- Uses small desktop app to load ArduPilot settings and waypoints, without having to work with code
- Adds throttle to altitude control, improving accuracy and wind performance
How do you calibrate the sensor without the control module?
2.0 is optimized for the EasyStar but this plane doesn't have ailerons. You must have the lateral facing IR sensors controlling roll through rudder/polyhedral. How does this compare to aileron control?
@Chris/Jordi: Does this do coordinated turns or was that just the alpha code? I got my flying wing together and tested indoors last night, was planning on hacking together something from the alpha to use on it.
It's set up with the EM406A, and ardupilot 2.0 pinouts with X/Y head on the analog ins, calibrate on digital.
Also, is there any alpha/beta or similar implementing the airspeed sensor? I should be getting my components to throw one together in a week or two.
is it possible to use the Z-sensor of the formerly FMA FS-8 copilot for the 2.1 (have one laying around here) ?
Erwin
Erwin
7
8
9
10
11
of 11 Next
