- All the ArduPilot 1.0 functions: programmable 3D waypoints; return-to-launch mode, in-flight reset ability, fully programmable actions at waypoint and totally expandable board.
- Now integrates the stabilization and navigation functions, eliminating the need for a FMA Co-Pilot and vastly improving waypoint tracking
- Controls elevator and ailerons/rudder. Throttle control coming in 2.1
- "Fly-by-wire" mode stabilizes the aircraft in RC mode, duplicating the function of the FMA Co-Pilot
- Stores home waypoints and sensor calibration in EEPROM, so they are retained even in the case of a system restart
- Controls altitude with the elevator, vastly improving performance in wind
- Currently optimized for the three-channel EasyStar. Versions have also been tested on Funjet and four-channel Superstar (code coming soon)
- Simple in-field calibration process
- Can use any thermopile XY sensors (default settings are for the FMA sensor, but Paparazzi, AttoPilot and custom sensors can also be used)
- Currently supports the EM406 GPS. Support for Locosys and Ublox GPS modules coming soon
- Uses "chained PID loops" to combine the stabilization and navigation functions seamlessly
- ArduPilot board ($24.95)
- EM406 GPS module ($59.95)
- A FMA XY sensor ($42.95; if you already have a FMA Co-Pilot, you can use its sensor). If you're buying the FMA sensor by itself, you'll also need to purchase a cable.
- A FTDI cable, such as the Sparkfun ($13.95) or Adafruit ($20) ones
- ArduPilot 2.0 code (Free)
- Uses Z sensor for self-calibration in the field
- Uses small desktop app to load ArduPilot settings and waypoints, without having to work with code
- Adds throttle to altitude control, improving accuracy and wind performance
I know i ´m being boring, but i don´t like too much the idea, in that case i would prefer to use a complete FMA pilot and V1x software.
To change the code and use a parser for NMEA ( Jordi talked about "emulation" ? ) requires (i think) programming knowledge that i don ´t have. (And i am not sure if that could fix the speed protocol problem).
But that´s cool, i just wanted to mention a possible improvement, not to mess up :-) ...
Quote:
"William,
I will develop a visual C# app that will read an special ardupilot telemetry (compressed) and transfer the data to Google Earth...
NMEA was designed for marine ships, not for airplanes. They are some pros about using Binary Protocol, specially with atmega168 that has not much power.. . "
Will a XBee @ 9600 be usable in this application?
Yeah, i'm going to do this for right now. My new 900mhz Xbee XSC modules arrived yesterday, and they are limited to 9600 Baud.
That´s cool, please could you explain how to do that and if it will fix the speed issue too ?
5
6
7
8
9
of 11 Next
