Just joined up! I fly RC Helis and planes and would like to get into UAVs. I have looked at you setup and it looks great. I have only worked with MicroChip PICs and use PicBasic Pro as well as assembly coding, so understand the workings of microprocessors, just not the one you use.
I have an E Flight Apprentice trainer that might be a good candidate for the UAV (lots of payload). It has the Spektrum 2.4 GHz Tx/Rx. Have a 7 Channel Tx. It uses a Y Harness for the ailerons. It does have a digital servo for the elevators. Will your hardware support digital servos?
I'm sure I will have more questions as I learn more.
It's easy, just cut the servo extension cables to the lenght required, solder directly to Ap and it's done.
Save the extensions remain tips to other uses.
Does anyone know where I can buy the cables that go between Ardupilot and my Receiver? I know it sounds like a basic problem but all I can find is servo extension cables which have the wrong end on one side so I cant link my board to the receiver.
Since It's a complete computer [albeit skimpy on the specs...], you should be able to control everything through it... [servos through usb, camera as a webcam, as well as a sd card for movies and stuff...
John
It's the equivalent of a vaioP in a credit-card sized "slot":
http://www.toradex.com/En/Products/Robin_Z530_Z510
