ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • Hi guys, Jordi could you please tell me what is the pulse width in ms, in order to activate the RH and waypoint navigation in the AP ?
    thanks in advance
  • steve,
    as Chris told you we are discusting this particular point on HappyKillmore thread but even if you can't read the home position ( with official config tool and happykillmore's one)
    home seems to be write correctly into EEprom!!
    Check out HappyK's post thread; he's working on this last bug. In the meantime, try Jordi's original? I don't think it affects your waypoints; just your home position. So if you make your last waypoint "home" it will come back.
  • T3
    Hi all, I seem to have everything ready for another test on wed night but I can't seem to get my home position to read off the board... I am using the latest config tool from the code page.
    When I hit red it says that it reads sucessfully and when I write waypoints to it I can read them back... but I cant get home to come up anywhere...
    I set the jumper, set switch to manual, power the board the blue light flashes, I unplug the bind plug, it gets a lock, moved the control surfaces, I reset the board, unplug the gps (so that I can read and write to the board) then hit read... it says it reads it fine but does not bring up my home position...
    any thoughts?
  • Chris, I think it was a power supply problem.
    Earl
  • @Ric,
    Spot on Ric, its a 241 (242 ohm) will change it out :) Jordi maybe a heads up on this, could be the only one tho...
    Rgrds
    Sarel Wagner
  • Check the resistor on the board. It could be a 240Ohm (n 241), instead of a 240K (n 244).
    Regards
    Ric
  • My System voltage is 5050mV under load measured with a DMM. The battery voltage on the sense pin is 12.1V. The .h file variable is set to 5050mv. Will go back and put the scope on it and see what the exact voltage are.
    Rgrds
    Sarel
    Yes that is correct. In that way you can do an accurate conversation.
    Neat idea on that perf board bridge, Earl!
    As for your GPS problem, I'm afraid don't know how to advise you. It works fine in my setup right out of the box, so I'd need to understand all the various ways yours differs from the recommended configuration to try to zero in on what's going wrong.
