ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
    Are you sure you're not just getting confused between decimal and minutes-and-seconds GPS coordinates?
  • OK, I have now confirmed it! The Ardupilot software is massaging the reported lat and long put out to the ground station.
    This is what comes out the XBee to the ground station LAT:34.618116 Lon:106.320600
    The ublox serial port is reporting lat = 34.511842 and long = -106.1970116
    I have confirmed this information by reading the ublox serial port while reading the XBee port on another serial port at the same time.
    No wonder the google map in the ground station is showing my plane in the wrong place by about 10 miles.
    ANYONE else have this problem or am I doing SOMETHING wrong ???
    SW 2.231
    Earl
  • Anyone else having a problem with the ground station on Google maps showing current location about 10 miles off ? Street atlas USA using the same port and data shows the current location in the proper place.
  • How are the following SBAS parameters of the U-Blox5 GPS reciever configured before shipping ?
    Mode - SBAS Subsystem
    Mode - Allow test mode usage
    Services/Usage - Ranging
    I do have win7 and i have no problems...
  • I just received my copy of Windows 7 Signature Edition last Friday. I was going to install it on my laptop and am wondering if there are any compatibility issues with the various software packages needed to upload, test, receive telemetry, etc with the Ardupilot. I am thinking that I might be the first to have to give it a try and report back. Anyone have comments?
  • Yes cache help. I can tracking with GE without internet connection. Thanks
    Maybe there's a way to run GE in cache mode? I'm not sure....
  • Chris, I there any alternative way to use the Ground Station realtime tracking while flying with no Internet connection. Google Earth need internet connection.
    When you click on the Google Earth button in the ground station software, it should come right up with the plane icon showing current position. If it's not working, you may not have an internet connection or your firewall could be block GE.
