ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • hi, Chris,
    i should say that i'm pretty lost with those versions...
    i'll wait until the latest beta version appears here.
    i'm not sure but i guess the latest Jean louis naudin's release could have corrupted my eeprom at start up,
    does anyone tried this version (i guess 2.4.6) and had trouble when going back to older versions? (like write error??)
    maybe it's only my setup doing that... i'm NOT blaming this version at all!
    just asking
    Yep, we need to start using our internal numbers for public releases. Sorry about that. Let me dig around and see if I can find the latest beta-tested version, and update the zip with that.
  • Hmm, I have the Nov 5 release (which is what the main page links to), but I don't see any way to identify whether it's 2.4.3 or 2.4.6.
    Mike, the SVN repository is our latest dev version but not beta tested. Once we test something we release it in the download section. But we're a little behind at the moment. Were you able to find 2.4.6?
  • Aha! What's downloading from the downloads tab is different from what's in the SVN repository! If you follow the link from the main page, ("Latest autopilot code (for the board's main processor, an Atmega328) is here.")you don't get the current code.
  • That should be:
    /**ArduPilot Version 2.4**/
    in the "ArduPilot_EasyStar_V24" tab.
  • Hmm, the version I'm using, and the one I downloaded just now (using the featured download) are both marked "Ardupilot 2.4" in the main tab. Should I be looking somewhere specific for the detail version number?
  • Re-quote...*Bug in 2.4.3....
    the dyslexic athiest lives in fear of DOG... :~)
  • Mike, what version of ArduP Software are you using as there was a butin 2.4.3, but fixed in 2.4.6
    Went down this road and had all kinds of problems, if it is the old software, update, or post it and i will post my crude(but functional) work around for 2.4.3
    hope this helps.
    Doc.
    It's supposed to zero during the calibration process (bind plug) on the ground. Not sure why yours isn't working...
