ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
    To use Remzibi, download and run Ardupilot 2.4. We made so many architectural changes in 2.5 and 2.6 that Remzibi needs to be rewritten. Anyone care to help with that now that things have settled down?
    http://ardupilot.googlecode.com/files/ArduPilot_24.zip
    Thanks!
    I just updated a minor fix to help with getting GPS Lock.
    Download it at:
    http://ardupilot.googlecode.com/files/Ardupilot_25_04.zip
    Aaron,
    Yes, you cannot load code when the GPS is plugged into the main board. The shield has a multiplexer to avoid that problem. It's been a while since I tried a EM406 with ArduPilot but I'll try it tonight and see if we've broken something in the EM406 code...most of the community has upgraded to the uBlox so we haven't been testing the older GPS modules with every code rev.
  • Thank you for getting back to me on the RC controller. I have a friend that will let me burrow his 6ch controller. I am still having trouble getting a GPS lock. I have the ardupilot hooked up to my laptop for programming. In my header i have the GPS_Protocol set to 1, i am using the EM406 GPS. Light is very dim need to cup my hands around my eyes just to be able to see it. But the blue LED just keeps flashing away. Does it matter what board the GPS is plugged into? When the GPS is plugged into the BLUE shield board I can upload the code to the board and the blue LED flashes away (inserted a Serial.println to show in the teriminal that it is waiting for a GPS lock in addition to the flashing LED) . When I plug the GPS into the RED ardupilot board and try to upload I get a error message saying the COM port is in use.
    Any ideas? Thanks in advance!
    Luis, that post is about an emulator, not the regular AP.
  • Ok but i have read on this forum http://diydrones.com/profiles/blogs/remzibi-osds-gps-emulator-now that this should work i just dont know if i can make this change the other possibility is to have 2 GPS one for OSD and other for the Autopilot!!!
    Luis,
    We have not fully integrated Remzibi with ArduPilot yet, so I can't answer the question about the GPS. We're certainly planning to allow you to use one GPS for both, but I can't verify that it's working yet.
  • For power i would like to know how did you power it?i have to power all this:
    1.3ghz 500mw 5v transmitter;
    5v camera;
    the Ardupilot and expansion bord;
    Remzibi´s OSD and GPS
    so can i put some of this together like one battery for the transmiter+camera and another one for the Ardupilot+OSD+ GPS. What size should be the batterys for this? 2000mAh is ok? My aeroplane is a Senior Telemaster with 2400mm wing span and a 26cc gasoline engine. I can get 30 minuts of fligth with a single tank.
