ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • Yesterday I have fly test with 2.5.04 Stabilize and FLY BY WIRE. WOW it's the best stabilize and flybywire, I have flown. It ROCK!!!.
    In stabilize mode, I give the radio to my 4 years old son (He never fly any RC before) and he can fly with just change the direction with rudder ONLY! I set the throttle to minimum (full down) sometime 1/3 up. Nice he can flew for about 20minute.
    Tomorrow I will test the AUTO mode and RTL by switching OFF my radio. And will tell you the result . Thanks again
  • When I power up the board with no GPS it goes into stabilization mode, the yellow status light blinks like it should indicating that the autopilot is running. Two nights ago I thought I got a GPS lock when I plugged the EM406 into the red ardupilot board. Blue LED flashed for a few seconds turned of for a couple of more seconds and then went solid Blue. I got a lock 3 times in a row ( this was in an old TI building, metal is everywhere) tried to replicate it again yesterday outside in the field next to the building and nothing,... It just keeps flashing, I'll try the GPS tester to see if I get any results. I will post the results later tonight.
    The Ardupilot doesn't really care if the GPS is connected or doesn't have lock. the results are the same - no navigation - go into failsafe mode if in autopilot. Failsafe with no GPS means gentle circling.
    Download the raw GPS tester to see if you are getting any output at all. Then use the 406 tester to just look for lock. It can take up to ten minutes to get a cold lock. Be sure you are near a window. Be sure you set up your header file correctly. Even better, don't use the shield. The serial mux might be setup wrong if you don't have the correct shield version.
    Make sure your Serial window is set to 56K
    Jason
  • Hmm... is there any way to know via ArduPilot that the GPS is still indeed alive? I tried out powering up the board without attaching the GPS. And whattdya' know... I get the same messages...
    The 406 is 57k baud so be careful
    there. Also, the no GPS message means you have not had GPS lock for 20 seconds. The plane goes into a failsafe mode when this happens. It doesn't mean it can't see your gps, just that it isn't getting location data from it. Just zeros.
    Make sure you give it tine to lock and your sure you are in a good place to get lock. If you try indoors or only wait a minute or two you'll never get lock.
    There is also a raw GPS output app if you want to see the codes that come out. I believe I included a spreadsheet to decipher it.
  • @jason - Some additional info... using the EM_406 tester file...
    4800 baud - $PSRF100,0,57600,8,1,0*37 (then jumbled characters all throughout...)
    57600 baud - init_gps
    Wait for GPS
    Still Waiting: No Valid Fix
    no GPS, last 10s
    no GPS, last 10s
  • @jason - Actually I did... and all I get was a "Begin GPS Test" prompt on 38400baud...
    Download the gps tester and run that. I don't think you have a problem with the dim light.
  • @Aaron,Chris - I've been getting the same problem on my EM-406. I'm getting a very very dim GPS light. And I'm getting a 'no gps' prompt on the serial terminal... i've got my GPS_PROTOCOL set to "1". Does it mean that I have to wait for my EM-406 for a week to forget all the settings?
  • Can i use this GPS modul on the Ardupilot? http://www.flytron.com/15-damnvision-gps-module.html
