ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • @Florin, I am having the same problem with it on my laptop. I think it might possibly be your firewall is blocking the program from accessing google maps. Another possiblity is that the ConfigTool uses the .Net Framework. You could try reinstalling/updating that.
    I have a question that deals with the waypoints themselves. When using the ConfigTool it lists all the waypoints out on the left in a list. I would like to know what is the format of that list when it is sent to the ArduPilot?
    Yes, ArduPilot can do elevons and works great with flying wings. See section 1-1 of the config file.
    //1-1
    #define MIXING_MODE 0 //Servo mixing mode 0 = Normal, 1 = Elevons (or v tail)
  • Florin,
    Did you see the blue led light on solid on the Mega board? This indicate the GPS signal locked.
    thanks
    There is a raw GPS app in the downloads section. Run that and send me the output. I'll let you know what codes it is outputting. You can post the text file right here.
    Florin,
    As discussed in the manual, the uBlox module needs to be programmed. If you bought it from the DIY Drones store, we do that for you. If you buy it from another source, you need to do it yourself following these instructions.
    @Luis - generally there is no problem using two gps receivers. Potentially you may have to separate them a bit, but I have operated two within 10 cm of each other without problem.
    @Florin - the ublox are sensitive to low voltage, but in my experience 4.8 volts should be no problem. I usually have problems with getting lock with input voltages below 4.5.
  • Chris can i use the Ardupilot with 2 GPS module? because i would like to use as an OSD the Remzibi or the Black Stork OSD and this last one have its own GPS atached. So my question is: if i use the Black Stork OSD with is GPS can i use another GPS just for the Ardupilot for the autopilot tasks?
    Aaron, you didn't link to the plane so I don't know which one you're referring to (a Google search was of no help, since there are dozens that fit that description). But in general any 40+ size high wing trainer would do, from a Telemaster to a NexStar
  • I want your thoughts on the Parkflyer Cessna 182 RTF as a platform for the Ardupilot. My teammates and I are concerned that it won't provide enough lifting power with everything onboard (ardupilot, two Lipo batteries, a small 2.4Ghz micro camera, Hammer Board, and Bluetooth AirCable(this thing has a 30Km range, insane for bluetooth). Two weeks ago we tried flying the Cessna with nothing in it and needless to we crashed it several times with some major repairs. Any recommendations for a plane that is easy to fly and can carry a payload up to say 2lbs?
