ArduPilot (Legacy) main page
3689315381?profile=original
[This original ArduPilot board, now called the "Legacy ArduPilot" is no longer produced or officially supported by the DIY Drones dev team, and this page is maintained just for historic reasons. However, there are still many users of it out there and it still works fine. The user group for Legacy ArduPilot users, for both thermopile and IMU use, is here.]
ArduPilot is a full-featured autopilot based on the Arduino open-source hardware platform. It uses infrared (thermopile) sensors or an IMU for stabilization and GPS for navigation. It is the autopilot used to win the 2009 Sparkfun Autonomous Vehicle Competition.
The hardware is available from Sparkfun for $24.95. An expansion board ("Shield") kits that includes an airspeed sensor, a 3.3v power regulator for 3.3v GPS modules and other sensors and cables and connectors for easy attachment of the XY and Z sensors, is available from our own store for $57.20.
User f
ArduPilot features include:
  • Can be used for an autonomous aircraft, car or boat.
  • Built-in hardware failsafe that uses a separate circuit (multiplexer chip and ATTiny processor) to transfer control from the RC system to the autopilot and back again. Includes ability to reboot the main processor in mid-flight.
  • Multiple 3D waypoints (limited only by memory)
  • Altitude controlled with the elevator and throttle
  • Comes with a 6-pin GPS connector for the 4Hz uBlox5 or 1hz EM406 GPS modules.
  • Has six spare analog inputs (with ADC on each) and six spare digital input/outputs to add additional sensors
  • Supports addition of wireless modules for real-time telemetry
  • Based on a 16MhZ Atmega328 processor. Total onboard processing power aprox 24 MIPS.
  • Very small: 30mm x 47mm
  • Can be powered by either the RC receiver or a separate battery
  • Four RC-in channels (plus the autopilot on/off channel) can be processed by the autopilot. Autopilot can also control four channels out.
  • LEDs for power, failsafe (on/off), status and GPS (satellite lock).
Resources:
ArduPilot requires the free Arduino IDE to edit and upload the code to the ArduPilot board.
The code is currently optimized for the Mutiplex EasyStar three-channel powered glider and FMA sensors, but can be modified for other aircraft and sensors. It uses the rudder/ailerons and elevator to maintain level flight and navigate to GPS waypoints. It supports a desktop setup utility and ground station software. It also includes a "fly-by-wire" mode that simply stabilizes RC flight. The main code is ArduPilot2.x.zip in the download section of our Google Code repository, where x is the latest version.
What you need to make a fully-functional autopilot:
Open source extras:
  • If you want to build your own board from scratch, the necessary files and component lists are here.
  • [Note: you shouldn't need this, since this code is loaded on the ArduPilot board at the factory] Latest multiplexer code (for the board's second processor, an Attiny, which runs the failsafe system) is here.
    Instructions for loading this code are here.
Recommended UAV setup:
3689303688?profile=original
Airframe option one: Hobbico SuperStar (49" wingspan, $95, shown above). This is an inexpensive, good flying high-wing trainer with ailerons. It can be hand launched in a park or take off from a runway, and replacement parts are readily available in case of a crash. If you want much better performance with this aircraft, you can upgrade it to a brushless motor, speed controller and a LiPo battery. [If you don't already have one, you'll also need a balancing charger and power supply.] Note: any stable aircraft with both ailerons (for stabilization) and rudder (for navigation) can work, so feel free to experiment with what you've got.
3689313666?profile=original
Airframe option two (recommended for ArduPilot 2.x): EasyStar (shown above). Performance can be improved with the modifications described in this post.
You'll also need:
  • A six or seven channel RC transmitter and receiver, with at least one toggle switch (ideally three-position but two-position will work, too, although you will have to mix channels to have access to both autopilot modes in the air), such as the Futaba 7C.
  • Some servos (at least three for ArduPilot 1.0; at least two for ArduPilot 2.x) and at least three female-to-female servo cables to connect the RC receiver to ArduPilot.
Cool optional extras for your UAV:
  • ok, fair enough...
    As I've got you helping me out, could you tell me if it makes any difference that I use FMA xyz sensors, is there any part of the code that needs to be altered or appended?
    Thanks,
    Jan
    Actually, 2.6 was released in Feb (here). We just do nightly builds.
  • Hey Chris,
    sure, I remember writing this ;)
    I tried having both GPS and serial monitor, it didn't seem to work, I will try again.
    I was willing to use 2.4 version because of Jean-Louis Naudin self teaching mode.
    True 2.6 IS the latest version, it got released 9 hours ago so it seems, thanks for the info.
    I will keep you updated as I always do, thanks for the very quick answers, I appreciate :)
    Jan
    Jan,
    The reason I thought your GPS was connected to the serial port is that you said it was! ("...since GPS is connected to serial port...")
    Yes, you can have the GPS and serial monitor on the same serial port. GPS takes Rx line and the serial monitor takes the Tx line. Did you try?
    I'm not quite sure why you're using very old versions of the software. The current version is 2.6. The manual is correct, it's just that it doesn't cover outdated versions of the software. We assume everyone will use the latest version.
    Please upgrade to 2.6 and let us know how that goes.
  • "you can't have serial monitor AND GPS connected together can you" should read "you can't have serial monitor AND GPS connected at the same time can you
  • Chris,
    thanks a lot for your quick answer :)
    Of course I followed the manual, and of course everything is soldered and connected the way it should, otherwise I wouldn't ask for help would I?
    I just managed to get the GPS working, for this it had to set in binary mode (something 2.4.7 didn't seem to do) so I finally uploaded 2.2.3, powered with the bind plug on and my GPS got updated and fixed in less than 30 seconds.
    Now, you tell me about reading the manual, of course, but the manual is not up to date so it seems, and there has been so many versions of software, shields and sensors it's really not easy to keep track.
    GPS Tester : of course GPS is not connected to serial port (!?) but it seems that on v1 shield (red) that I use it happens to share the serial port doesn't it? So if it does, you can't have serial monitor AND GPS connected together can you?
    Something else : I'm not a native english speaker, I'm french and probably make mistakes or write things in such a way that they are not clear, sorry.
    You should bear such things in mind before lecturing those who follow you and participate to the economical success of your company...
    Thanks for a good project,
    Jan :)
    Jan,
    First, if the red LED is on on EM406 that means it hasn't been switched into binary mode. Have you read the manual and set up your autopilot properly, setting the configuration file for SiRF and either soldering on the jumper wires for throttle control or used a bind plug for startup?
    Second, I don't understand what you're saying about the GPS tester. The GPS module is supposed to be connected to ArduPilot, not directly to the serial port. Again, the manual explains how to use this test with the serial monitor.
    You have to read and follow the manual step by step or nothing will work. Maybe someday we'll have plug and play autopilots, but right now it's very much RTFM.
  • ok, feedback :
    all is good, only EM406 GPS is causing problems.
    When connected to shield and Airframe_test loaded, the led on the GPS was first steady red, and now it is and remains flasihing red at 1Hz (I can reset, it keeps flashing red).
    I tried to run "RAW_GPS_tester, but since GPS is connected to serial port, neither the GPS nor the serial monitor work...
    Any help someone, please?
    Jan
  • Thanks Doug!
    @Aaron
    #define THROTTLE_CRUISE 125
    set it to 125. It is on a 0 to 125 scale.
