ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
APM 2.5 autopilot with GPS ($179)
[Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • Just got the connectors soldered to the APM. Successfully processing all 8 PWM inputs, reading and scaling rate gyro and accel data. Progress!
    John
  • I just tried that code to bench test my mega also, but I get "51:error APM_RC.h: no such file or directory"
  • I just received the UBLOX GPS and adapter. I used the 6 wire extension cable that I had used for the 406 on Ardupilot (I assume that is the same cable) and connected it up to ArduPilotMega but don't get anything at all from it. Is there something I am supposed to do or has it failed. I simply plugged the adapter in carefully, added the cable - nothing from the GPS UBLOX library test or ArduPilotMega_1_0.
    Thomas, here is the ArduPilotMega_1_0.zip setup for a Stryker_II all gains need tuning... use at own risk not tested in air.. running on ATmega beta board
    https://storage.ning.com/topology/rest/1.0/file/get/3692057402?profile=original
  • I think what's going on is that a standard rc receiver battery (4.8V) does not have enough juice to power the board, and I have to upgrade to a 6V rc receiver battery.
  • I can't seem to get enough current to the holux for it to get a fix :/
  • @TCIII and Darren,
    Thanks for the assistance! I finally am getting some reasonable numbers from the APM_1_0 code (haven't tried copter yet) - pitch and roll are fixed at about 4 to 6 and holding constant and seem to give reasonable values as I move the board stack +-45 degrees. I don't have a GPS connected yet and I am getting yaw slewing at about 10 degrees per second. I think I had a small solder bridge which was affecting the accel/gyro readings - all sorts of problems to fall into!
  • Have you tried the arducopter code?
    See if the IMU data looks solid with it.
    I'm getting different results from apm_1_0 vs arducopter. (both are just still beta but getting there :)
  • You all,
    I tried downloading and running the APM_IMU_test and after adding the above APM_ADC files, I could compile and upload but the results look nonsensical - that is, pitch, roll, yaw are just counting up - not constant. Is it possible that I have an old version or incompatible versions?
    Thanks for library files, compiles great, spits data out fast... 1st APM test APM_log_1st_testlog
