ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
    Johannes: Is your uBlox programmed for ArduPilot?
  • I have been patiently waiting in the background as I cannot put the APM in my plane until late August when I get home but I had a couple questions if someone could help me.
    - What are the options going to be for connecting the xbees to the APM? Does it need to go to the telemetry port or is there somewhere else?
    -My ublox GPS isnt communicating(led C). Loaded the APM demo last week and then loaded the APM 1_0 succesfully last night and it still dosnt work. Am i missing something? Left it outside for a while and not even a flash from the LED.
    -Neil
  • @ Daniel
    Yah, that is the one. Or you can get the 15 cm one.
  • @ Daniel
    Yes, it works. I just posted proof here. Make sure you also buy the JST cable so that you can connect it to the APM
  • ■AirSpeed sensor port (optional, sold separately).
    Which one to get?
    MPXV7002DP (in stock) or MPXV5004DP (out of stock)
    or even better, MPXV5004DP (also out of stock) which comes with pitot and tubes.
    @Jonathan. As I said, no.
  • @ChrisAnderson, so do i need get this --> http://store.diydrones.com/product_p/br-ppme.htm
    @Jonathan. No. The PPM encoder is already on the APM board.
  • yes ... yes ... yes ... today is my birthday
    my best gif will see the ardupilot mega working on my quad frame.
    my ardupilot mega are installed on the frame and waiting for code.
    regards.
  • I'm ready to help test the quadcopter code. I have an older Draganfly and I am ready to throw the controller out and install the ArduPilotMega board. Do you have an eta for the release, if not, may I ask how stable the current code is for the Quad design?
