ArduPlane home page
3689354430?profile=original
3689312509?profile=original
Convert any RC airplane into a fully-autonomous UAV!
Just add the APM 2 autopilot to any RC aircraft and it becomes a fully-programmable flying robot with a powerful ground station and Mission Planner.
Features include:
  • Return to Launch with a flick of your RC toggle switch or a mouse click in the graphical Ground Station
  • Unlimited 3D GPS waypoints
  • Built-in camera control
  • Fully-scriptable missions
  • One-click software load, and easy point-and-click configuration in the powerful Mission Planner. NO programming required!
  • Replay recorded missions and analyze all the data with a graphing interface
  • Supports two-way telemetry with Xbee wireless modules.
  • Point-and-click waypoint entry or real-time mission commands while the UAV is in the air
  • Fly with a joystick or gamepad via your PC--no need for RC control!
  • Built-in failsafe will bring your aircraft home in the case of radio loss
All instructions and software are here.
3689354391?profile=original
3689354242?profile=original
APM 2 is an open source, Arduino-compatible, pro-quality autopilot. It is the most advanced IMU-based open source autopilot available today, and provides an entire UAV control system with scriptable missions with 3D waypoints, in-flight uploading of commands and powerful ground station software.
APM 2 supports any kind of of vehicle with a one-click change of code. Available code include ArduPlane (fixed wing), ArduCopter (rotary wing), ArduRover (ground vehicles) and more.
Everything you need to create an ArduPlane UAV:
*  APM 2.5 autopilot with GPS ($179)
*  [Optional] Telemetry kit ($75).
3689354459?profile=original
You'll also need a at least a five-channel RC radio setup, a soldering iron, a mini USB cable and of course something that flies!3689354440?profile=original (We're partial to the SkyFun delta wing (right) and
Bixlee 2   powered glider (left) or its equivalents ourselves).
Resources:
Manual
Source code/firmware
Note: ArduPilot Mega requires no programming, but it's open source and you're welcome to modify it if you'd like. If you are going to play with the code, you can use the free Arduino IDE to edit and upload the code to the ArduPilot board.
  • Hey, I see that this and the mediatek GPS receiver are both out of stock in your store. I'm eager to purchase this wonderful design! Any ETA on more boards / gps?
    Uwe, the tutorial for programming the uBlox is here. If you didn't specify that it should be programmed for ArduPilot when you order it, it will come with 9600 NMEA.
    You will need to download the software U-center from U-blox site and will need this txt configuration file:ublox5_helix_v11.txt.
  • Mmmmmmm... getting close to the beginning of July....
    Earl
    @Daniel:
    The name have "Shield/OilPan" because it's possible to attach it by the two ways. One of the main advantages of use it as shield is the existence of mounting holes on APM. So with APM at the base, you can use those holes. When you mount APM with bolts on the ArduCopter's plates, for example, you have a more secure and affordable way to manipulate all the connectors (PWM/RX, GPS or the Compass module on the IMU shield as well ).
    Regards.
  • @Chris and I'm getting a 10channel transmitter. Is it enough?
  • @Chris the codes meaning the input to the boards. and the manual meaning?
  • Upgraded to the latest version and just got the 171 update.
    Out of curiosity, has anyone got this running on a BETA main board yet? We've figured out the HW MUX is on a different channel, and I can switch modes and have full Tx control now, but I'm getting no response to the servos from IMU movement.
    Just wondering if we have "known" config changes necessary from beta to production firmware.
    JC
    @John C: Are you behind a proxy server?
    John C. Not sure what you're doing wrong with Tortoise. Works fine for me:
